Pennzoil Platinum 5W30 appears to be removing oil varnish from inside my Gen 2 cylinder head cover
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jadziasman, Apr 10, 2014.
  1. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    I just noticed something that might be beneficial to my 05 Prius with 217K miles.
    Since I purchased my Prius in Oct 2010, I have used the following synthetic oils: Mobil 1, G-Oil, Pennzoil Ultra and now Pennzoil Platinum. I have changed the oil myself, approximately 16 times (every 5000 miles).
    The last oil change was with PP and I was amazed to find that the oil varnish has completely dissolved and the baffle plate is clean and shiny after driving 3300 miles with PP. There had always been a film of oil varnish on the baffle plate underneath the oil fill cap since I bought it when using all of the other motor oils. PU was the last oil I used before PP.
    There is a possibility that PP will dissolve most of the oil varnish deposits inside the cylinder head cover and maybe in the piston oil ring grooves as well. If so, the oil consumption my car has (about 1 qt every 3500 miles) might decrease a little, which would be nice.
    I will continue to use PP for the next few oil changes and see if the baffle plate remains free and clear of oil varnish.
    PriusGuy32 likes this.
  2. JC91006
    16,496
    8,406
    This is good to know. I'm due for an oil change on my 2010 and it burns a little oil now. I'm going to try this and see if there's any improvements
  3. xliderider
    xliderider Senior Member
    7,894
    3,129
    Honolulu, HI
    My last oil change was with 0w-20 PP.
    SCH-I535
  4. Former Member 68813
    3,524
    981
    US
    Pennzoil advertizes their oils as the cleanest of all. There must be some truth in the advertisement after all. We do know that they pioneered Gas-to-liquid manufacturing process that gives the best quality group III oils.
  5. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    OTOH, on a car with that many miles, removing the accumulated varnish might make your oil consumption go UP too.
    Please keep us posted.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    What do you all think about using this oil in a 2004 Chevy Venture with 110,000 mi. on it? It's my wife's van that gets used mostly around town with just an occasional highway trip. I've noticed over the past year the inside of the engine where you pour the oil in seems to be getting pretty dirty and the oil seems to be getting black after just a thousand or so miles. I was thinking of using this oil but worry about changing to synthetic oil after all these miles. It's always had just "regular" oil usually Pennzoil or Quaker State. Thanks.
    PS the van only uses a qt. in 5k. mi.
  7. paprius4030
    2,077
    296
    York,Pa.
  8. Patrick Wong
    18,200
    6,479
    I would be cautious about switching to synthetic oil after such long use with mineral oil, if your intent is to minimize engine oil consumption. I think you should leave well enough alone.
  9. paprius4030
    2,077
    296
    York,Pa.
    Thanks Patrick. After mulling it over I agree. If it ain't broke don't fix it LOL.
  10. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    (in the software world) Corollary 1: if it ain't broke, fix it until it is!
    Corollary 2: if it ain't broke, it doesn't have enough features!
    DROID4 ?
    NR427 likes this.
  11. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
    Interesting. When I bought my 2007 it had 54500 miles on it. I changed the engine oil right away, and noticed a light varnish on the cam cover baffle. I ran my finger along it and it left a "swipe" mark. That swipe mark is now barely noticeable because the whole thing is getting covered by more varnish :mad: Ive used Mobil 1 almost exclusively during that time, changing every 5k-7k miles.
    I bought some Penz Plat 5w-30 on sale a few weeks ago for my next OCI. Im excited to hear that it might clean up the varnish (y) My ICE currently consumes about 1 quart every 5k miles, trivial amount I know but it is always a nice thing to strive for less oil consumption.
  12. JC91006
    16,496
    8,406
    Any updates on the use of Pennzoil platinum? I'm wondering if the Pennzoil Ultra was what cleaned the baffle plate prior to the OP using PP.
    #12 JC91006, Jun 12, 2014
  13. PriusGuy32
    1,417
    512
    I have 4,900 miles on this oil change of Pennzoil Platinum 5w30 and my engine has needed no top off oil!! Thats a first, ever for my Prius - I usually need 1/2 quart ever 2,500 miles or so.
    TheLastMojojomo likes this.
  14. JC91006
    16,496
    8,406
    Same here, pp seems to be holding up after 1000 miles with very little loss.
    Mobil 1 was going through oil quickly
  15. ChadInOKC
    ChadInOKC Junior Member
    46
    Moore, OK
    I think I might make the switch to PP 5w-30! My 2010 has been using quite a bit of oil at 108K now. I have about 8k miles since my last oil change and I bet I have added at least 3-4 quarts. It's sees considerable highway miles, so maybe that is part of the underlying issue.
  16. PriusGuy32
    1,417
    512
    Add Castrol Edge 5w/30 to the list of robust oils that somehow do not get burned by the prius. Ive been using it the last 10000 miles and have added NONE between oil change intervals. My experience with Pennzoil Platinum was similar.
    My Prius burned right through Mobil 1 though. I'd use 1/2-3/4 quart every 2500 miles with it. :confused:
  17. theforceprius
    theforceprius Junior Member
    25
    Woodward, OK
    I've had the same experience with Mobile 1. I have a 2005 Hyundai Elantra that had very bad build up. Five oil changes later and you wouldn't know it is the same engine. I am a believer in Mobile 1's claims of cleaning your engine. It is good to know there are others.
  18. theforceprius
    25
    Woodward, OK
    I'm reading here that folks are having oil consumption with their vehicles even in good condition. Is this normal? Is the Prius just hard on oil?
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Picture please, I don't know what the baffle plate is or what it does.
  20. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Not exactly hard on oil, but many people start noticing minor oil consumption after about 100k miles. Not everyone has the issue, some people say they see zero oil consumption even at moderate miles/age. People who drive hard and at high speed seem to notice it more often than people who mostly do slower "around town" type of trips. I'm not sure if it's related to the Atkinson cycle engine or somewhat low tension rings or whatever, but "for a Toyota" yes, many do seem to consume a bit more oil than normal.
    Anyway I see that you're a relatively new owner, so just keep a close eye on the dipstick for a while, at least until you can figure out how it's trending. Don't be alarmed or surprised if you find that you need to top it off a little between oil changes. Minor oil consumption is no real problem as long as you keep them topped off. Say for example you find that you're using about 1/2 a quart every 3k to 5k miles, that's actually pretty minor. Though obviously if you're seeing less consumption than this, then that's all the better. :)
    Merkey and theforceprius like this.
