Pepboys brake fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Aug 1, 2024 at 2:37 PM.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,906
    828
    Got the fluid changed out today and it all took an hour to do with all the bleeding.
    I did not see them use the OBD port or disconnect the 12v at all.
    They sucked out the reservoir first then started bleeding the right rear, then left rear and then right front and left front.
    No ABS lights on or any issues.
    All done for $69.99 plus tax for a total of $70.94
    First picture zoomed in is the old fluid and second picture is the new fluid. 20240308_135847-1.jpeg 20240801_110509-1.jpeg
  2. Tombukt2
    Tombukt2 Senior Member
    9,265
    1,624
    Durham NC
    Wow and that's in a California generation 3 no kidding My brake fluid here in North Carolina in the two generation threes that are permanently parked so far The fluid is almost water clear and both of these cars have one at 2:46 and the other 396 I thought this far along in the year models this newer.4 and later brake fluid doesn't eat the seals and turn black or get dark because it's eating the seals or whatever it was doing in the old days.
  3. Brian1954
    Brian1954 Active Member
    869
    319
    South Central PA, USA
    There is a difference between a brake fluid bleeding and brake fluid replacement. Brake fluid bleeding requires a scan tool. Brake fluid replacement doesn't require a scan tool. Pep Boys did a brake fluid replacement for you, not a brake fluid bleed.
