Performance Parts for the Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by kryuenger, Jul 15, 2007.
  1. kryuenger
    kryuenger New Member
    Hey everyone,
    I am a new prius owner, and coming from a rally/ grip driving background. How do i produce more horsepower, or at least some added pickup. What performance parts are out there? Can anyone help me out? Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(kryuenger @ Jul 15 2007, 04:13 PM) [snapback]479230[/snapback]</div>
    There really isn't any way, within reason, to do that. If you want a race vehicle or a sprint car you made a poor choice with the Prius. It has adequate get up and go for normal driving within safe and legal limits, but it is not designed for anything more aggressive.
    Note that this is not a restriction of the hybrid system, but rather a design choice for the Prius.
    Perhaps the car you want is the hybrid Supra blowing away all the competition in the currently running 24 hour race in Japan!
    http://priuschat.com/Toyota-Hybrid-Supra-p...pan-t36031.html
  3. kryuenger
    I just want a little bit more pick up from the Prius. I'm not looking to grip this car, but just a little more power.
  4. Tideland Prius
    16,155
    <div class='quotetop'>QUOTE(kryuenger @ Jul 15 2007, 02:21 PM) [snapback]479237[/snapback]</div>
    Perhaps losing weight is easier than adding power? Lose the spare tyre is a good start.
    I don't know if the Echo/Yaris/xA/xB parts will work even though it's the same engine (exhaust, CAI) but an air filter change may work....
  5. Doc Willie
    1,717
    142
    Out there, somewhere
    <div class='quotetop'>QUOTE(kryuenger @ Jul 15 2007, 05:21 PM) [snapback]479237[/snapback]</div>
    A tire change might make you feel a little more zippy. You can apparently get 205 width tires on this (see the tire threads) which may give you more grip and a zippier feel. Also increase the tire pressure - many folks run 42 front 40 rear. Finally, lighter wheels will help out, and not hurt your fuel economy.
    Most performance minded folk around here consider that the OEM tire (Goodyear Integrity) as not so hot.
  6. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    There's not much, if anything, you can do to add power to the Prius. You can make it go faster around corners with some chassis/suspension upgrades, but that's pretty much it. It's the wrong car for the 1/4 mile. Auto-x is a better route to go.
  7. kryuenger
    What is everyones suggestions for parts?
  8. richard schumacher
    7,663
    1,038
    United States
    Gold spinners and fuzzy dice.
  9. Doc Willie
    1,717
    142
    <div class='quotetop'>QUOTE(kryuenger @ Jul 16 2007, 12:24 AM) [snapback]479438[/snapback]</div>
    See the mod list in the signature in the post just above yours.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 15 2007, 09:45 PM) [snapback]479448[/snapback]</div>
    ROFLMAO! :lol:
  11. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Parts you want? Parts we got. If you want a real racing Prius, use only part number 4 from the big picture, and put the part from the second picture where the back seats used to go. All you need then is the window sticker that says 'Yeah, it's got a hemi' :) [attachmentid=9782] [attachmentid=9783]
  12. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    <div class='quotetop'>QUOTE(hyo silver @ Jul 16 2007, 12:04 PM) [snapback]479623[/snapback]</div>
    haha thats a nice layout of the prius and its parts i like it... and the idea does not sound bad at all... hahaha
    <div class='quotetop'>QUOTE(kryuenger @ Jul 15 2007, 05:13 PM) [snapback]479230[/snapback]</div>
    as for performance just the TOMs exhaust... not such a good request, not for the prius.. you can find almost anything for any other new toyota out there but not for the prius... you can tune the suspension components and work with the exterior a bit...
  13. omgitsroy326
    omgitsroy326 New Member
    267
    Los Angeles
    when you say rally grip... i mean seems kinda oxymoronish.. no ... prius and performance?
    did you drive a wrx... or like an alltrac or something???...
  14. kryuenger
    <div class='quotetop'>QUOTE(omgitsroy326 @ Nov 3 2007, 09:48 PM) [snapback]534550[/snapback]</div>
    i drove a wrx
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I wouldn't bother. It's never going to be fast and the effect on milage is not worth gaining a few 10ths of a second if you can even do such a thing in this car.
    Your best option is to try for weight reduction so you drop ET and raise MPG. That will likely increase interior noise and may look ugly but you are trying to go against what this car was designed for. :)
    I drag race and come from a history of fast cars and even I don't bother modifying this car for performance. :)
    Zeppo Shanski likes this.
  16. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(F8L @ Nov 7 2007, 12:53 AM) [snapback]535985[/snapback]</div>
    I'm learning, the hard way, that this car can actually seem like it's designed to confound any attempts to make it go faster.
    It's a really well balanced package, overall (for what it's designed to do), but as soon as you change pretty much anything, the balance begins to go away and I'm not sure the overall effect is always pleasurable. At least, be aware of it; that the balanced nature of the car as a whole can be easily disrupted...and is surprisingly noticeable in its absence.
    There was the Prius GT; basically, what they did is upped the battery voltage from 201 to 278 (or whatever it is in the Camry hybrid) and replaced the Atkinson cycle engine with the conventional Otto-cycle mill from I think it was, the Echo.
    But that's Toyota; they're the factory and have the computational horsepower and knowhow to make these new systems speak to each other and actually work together...I for one, don't have that knowledge and am not willing to spend the money to employ someone who does. The cost/benefit tradeoff simply isn't worth it to me.
    And there was that turbo'ed Prius Classic...which, even the folks who did the swap said was a LOT of work.
    I did, however, own a Monster Miata for a time...you know, the Miata with the pushrod 5.0 Ford V8 shoehorned into it by Monster Motorsports...that one, also, sacrificed a lot of the "balance" of an otherwise well-rounded car...but was absolutely, positively worth it in every respect (at least for a while).
  17. prius2go
    prius2go Member
    311
    There ought to be a way of pressing a red boost button to give extra electric torque when needed :rolleyes:
  18. chrisek
    chrisek geek
    94
    Carson City, NV
    I thought the guy/group that turbo'd the classic then took that off, supercharged it, didn't like that and then turbo'd it again. That was a NorCal guy. same one, or different? :confused:
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Then we would only need a cool LED display in the dash that spoke the words...
    KITT: Don't touch Turbo Boost. Something tells me you shouldn't touch Turbo Boost
    We've got nearly all the other gadgets. We just need the turbo :(
  20. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    It's good to see that I'm in the same boat with a bunch of doctoral candidates. It makes me feel like I've found my element.
    Performance tweaks on a Prius... I've heard of a turbocharged Prius, but to me that's a massively bad idea as turbos don't like being stopped and started without a warm-up / cool-down period. I'd rather see it supercharged, but either way you must keep in mind that a Prius has a low-RPM engine and as such is best suited to nitrous oxide injection.
    That having been said, this is not now and never will be a performance automobile. Someone else discussed drag racing, and I used to hobby race ( my convertible is not track legal anywhere anymore :( ), and the Prius is really really not an easy car to enhance, acceleration-wise.
    ~ dan ~
