Performance Proven Traction Battery
Discussion in 'Gen 2 Prius Main Forum' started by bmwbob89, Jan 22, 2020.
  1. bmwbob89
    bmwbob89 Junior Member
    Newburyport Ma
    Hey Gang. Now that I have your attention. I just picked up and installed a battery from a salvage yard that was installed about 2 years ago by the previous owner. I did have to drive 2 hours each way to get the battery but it was well worth it. I've been searching for quite awhile to find a used replaced battery. It was $500.00. Then another drive to return the core and get my core charge back. If you go down this road and I suggest you do make sure they send you a picture of the battery so can see the cover, The replacements have a bunch of stickers on them and the originals don't. Now my battery graph is not going from charged to really low very quickly. I put a photo so you know what to look for. Another yard said they had a recent battery but the picture they sent me showed they were wrong. The old owner told them that to get more money at the yard. They got hosed. I am now a happy more relaxed Prius owner.
    ydpplqbd likes this.
  2. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Nice work!!!!
  3. ETC(SS)
    7,355
    What was the core charge?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Nice find. That pack was assembled in July 2017.
    strawbrad likes this.
  5. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    Is it the Assembly No G9510-47031 that tells you that? Nothing else in any of the labels is very legible.
  6. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    I believe it's the serial number, H117UAL5003A. (Or is it H717... that would make more sense, I guess)
    #6 oldtechaa, Jan 23, 2020
    Data Daedalus and davecook89t like this.
  7. bmwbob89
    Newburyport Ma
    Core charge was 250. If it was 100 I would have kept it to tear it apart. So bottom line was 546ish. Sales tax on the 500. Sucked driving 4 hours twice but I'm retired and my brother went with me. We bickered the whole time. Kept us amused. About 3 hours in 21 degree temps to install. Well worth it. Now I still worry the brake system will fail at some point.
  8. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    For case cover serial numbers...
    H117U
    H=Prius
    11=day of month
    7=July
    U=2017
    For individual modules, the U would be 2019, so most likely the module serial numbers are May or June of 2017 so they would have an S code
  9. CanTG
    CanTG Junior Member
    can you point me to how to read the serial number? I’m trying to determine the year of manufacturer for serial #2345K14711008c150437
  10. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    It looks like the serial coding has changed. The s/n used to be 12 chars long, but this one is 20 char long.
    Maybe @TMR-JWAP, @strawbrad or @JC91006 who do a lot with batteries have seen this format before and know how to decode them.
    SFO and CanTG like this.
