Periodic beeping
Discussion in 'Gen 2 Prius Technical Discussion' started by 8AA, Sep 18, 2007.
  1. 8AA
    8AA Active Member
    550
    62
    Maryland
    My Dad reported that his Prius has started beeping once every 5 minutes. There is no indication on the dashboard or the MFD. My guess was that this is the warning the Prius makes if the battery in your keyfob is low. I suggested that he try the other fob, and the car did the same thing. It's possible that both fobs have nearly dead batteries, but it seems unlikely.
    Anyone else experience this phenomenon? He's planning on asking the dealership to look at it, but I wanted to make sure it wasn't something simple. I also told him how to open the fob so that he can try replacing the battery.
  2. bobdavisnpf
    bobdavisnpf Member
    149
    My kitchen does that all the time. It means the dishes are clean, or the smoke detector's battery needs changing.
    Sorry, I couldn't resist. ;)
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    if it was the keyfob there shouldnt there been a yellow light on the dash
    with the exclamation point on it?
    all the lights light up when you run out of gas and half the mfd is missing
    and if it was the door, the door light would of light up on the dash
    its a total mystery to me
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Have you left something in the glovebox or centre consul? Do you have kids with a tamagochi?
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    If he has 06 or newer, it might be low fuel warning. "Add Fuel" message display on the LCD screen and a beep about every 5 mins.
  6. 8AA
    8AA Active Member
    550
    62
    Maryland
    <div class='quotetop'>QUOTE(patsparks @ Sep 19 2007, 05:55 AM) [snapback]514701[/snapback]</div>
    patsparks was the closest. It ended up that it wasn't the car but rather the cellphone in the center console.
    However, I am still curious what happens when the fob battery is low. There is supposed to be some indication because one of the customizable options is to turn that warning off.
  7. bibs
    bibs Junior Member
    cape cod
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Sep 19 2007, 05:00 AM) [snapback]514702[/snapback]</div>
  8. paulagoodfellow
    paulagoodfellow Junior Member
    <div class='quotetop'>QUOTE(8AA @ Sep 19 2007, 05:32 PM) [snapback]515004[/snapback]</div>
    Ha, I parked up in the closest spot to the door of Michael's (the craft store) the other night, in my new Prius. When I touched the door to lock it, it began beeping strangely, I thought. Took my son and I a minute to figure out that it was the bar code reader in the store (door was open.)
  9. Randy Rued
    Randy Rued Junior Member
    Santa Rosa
    Hi all, I was getting a beep every 5 minutes for days. We went to Walgreens and replaced our fob batteries and the beep still was going every 5 minutes. I saw that "patsparks" said the cell phone was in the center console. We rarely use our flip phone and I checked it out and it was on. So thankful to see to make sure our flip phone was the problem causing the beep every 5 minutes.
  10. Randy Rued
    Santa Rosa
    Thanks patspark, you helped me solved a beeping noise every 5 minutes.
