Permanent hitches - do they affect MPG's?
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Feb 21, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I'm thinking a hitch might affect the airflow under a Prius car, even a small hitch for accomodating a bike rack. Just curious, without bike rack hanging on back, anyone noticed a drop in MPGs with hitch installed?
    Thanks in advance
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    It almost certainly does, I suspect not enough to be noticeable over the uncertainties in the equation.
  3. Tande
    Tande Active Member
    541
    322
    Mich.
    I've had one for the last 20,000 mi. ....can't say I can tell any difference.....but, I would agree; it probably doesn't help......
  4. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Certainly the weight is < 30lbs, so weight is no issue. Since the the thing is attached under the rear bumper, I can't imagine ant impact on the aerodynamic, my thought is there would be so small, if any impact it's simply no concern. There are other concerns but not MPG's.
  5. fuzzy1
    10,515
    The Tork hitch is mostly tucked inside, so it should have less impact than those where the crossbar is exposed. I haven't noticed any reduction, but am not in a position to do rigorous A/B tests. It is more expensive than others.
    With the rack and bike attached, highway mpg does drop quite significantly.
  6. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    I can't tell any difference in mpg. I have a Curt hitch. I think the weight is a much bigger factor than aerodynamic drag but the tow anchor that is removed from the left rear when installing the hitch is a heavy piece of steel so that mitigates the weight of the hitch somewhat.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    on longer distance drives (most of my commuting is short) i can still achieve above 45mpg. I've had my hitch on "forever" and i also have 17" tc rims... shrug.. i notice no difference. with a bike rack attached, i noticed a big difference.
    i tend to not speed on the highway... my brother does get better mpg than me when he travels at high speeds... so maybe in the end it only really effects at higher speeds (i rarely go above 70mph)
