perpendicular parking
Discussion in 'Prime Main Forum (2017-2022)' started by ems2158, Jun 12, 2017.
  1. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    Were we live there are a number of places where perpendicular parking in required. One of the drivers of our Prime Advanced has a tendency to smack the front bumper into the curb. Can the front sonar/parking assist help prevent this? I looked at the manual and it looks like a curb is too low to register on anything.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    NO.
    You need to adjust the driver, not the car.
    But in most cases, the plastic/rubber parts that hit will NOT be seriously damaged by an occasional scrape.
    Prius Maximus likes this.
  3. Washingtonian
    Washingtonian Senior Member
    716
    617
    I worry about that also. Remember back in the 50's (well, probably most of you weren't around then) when you could buy "fender feelers"? Looked like a little antenna on the front of your car to help you park. When they touched the curb they made a noise and you knew you were close enough. Wonder if there is a modern equivalent of those.
    priuscatprimeguy likes this.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    fender feelers | eBay
  5. Mendel Leisk
    38,730
    I would NOT make any assumptions, get under there and see what's happening. And the best defence: driver ed.
    On our 3rd gen, albeit a different vehicle, the frontmost underpanel was nearly coming apart, after a few years of curb brushes. It was backing off in particular that tore things up.
    alexcue likes this.
  6. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    Prius parts are replaceable....so is the driver. Pick whichever is cheaper or more convenience. :)
  7. Prius Maximus
    Prius Maximus Senior Member
    935
    780
    Northeastern IL
    The occasional scrape won't really do much damage as long as the impact is slow, but backing out is when the damage happens. Some of those curbs/parking bumpers are on the high side, and if hit hard enough could do some serious damage.
    Sounds like it's time to train the driver some more. Whenever I get a new car, I park it against a wall/garage door/whatever. I get out and look and move it up to where it's only a few inches from touching. Then I sit in it and memorize the wall position relative to the front end of the car. Picturing where this imaginary plane is in my mind later, I never get closer to parking bumpers etc than that imaginary plane.
    I do the same with the back end too, although with the cameras these days, that's not as important. In the old days, cars were boxy, and you could see where the edges/corners were. Made driving so much easier. Today, you can't see any edges and it's all your mental picture of where the edges could be.
    alexcue likes this.
  8. Sam Spade
    2,036
    1,023
    2017 Prius c
    Yes those are still available.
    Do some Google searching.
  9. priuscatprimeguy
    2,730
    2,640
    yup, I did just that and posted a link (see post #4)
    Prius from Dad likes this.
  10. Prius Maximus
    935
    780
    Northeastern IL
    I've always liked photos. Here's one for you youngin's to save you some data...
    P.S. You might look up whitewall tires too...
  11. priuscatprimeguy
    2,730
    2,640
    wait........is that a Prime???????:confused:
  12. Prius Maximus
    935
    780
    Northeastern IL
    Did anyone notice the custom air valve cap?
  13. Mendel Leisk
    38,730
    Last time I used those "catfish" feelers was maybe 20 years back, on inside back corner, to help with parallel parking. It was the spring style, was prone to snag-and-drag road debris, string and stuff. Gave up on it, just use caution and practice now.
  14. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I'd always heard them called "curb feelers".
    krushmoto likes this.
  15. krushmoto
    krushmoto Member
    65
    44
    US
    I feel old..I know what they are!
    Nexus 6P ?
