persistent P2238 after engine swap
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Jan 10, 2026 at 6:29 PM.
  1. stokesey
    stokesey Junior Member
    65
    Southern Cal
    P2238 Heated Oxygen Sensor Current Control Circuit Low
    This code pops up every 100 miles or so. The problem started after an engine swap.
    Have replaced the AFR/O2 sensor twice, once with cheapo and once with Bosch. Replaced exhaust flange gasket to cat.
    Definitely getting signal from the sensor. Here are some charts.
    Thanks for any advice
  2. stokesey
    65
    Southern Cal
    Top chart is cruising on freeway, bottom chart is coasting to a stop. The values seem plausible to me. But I'm not an expert on heated O2s.
  3. ChapmanF
    18,301
    You've shown the output signal from the sensor, but the code appears to be about the control circuit for the sensor's heater.
  4. stokesey
    65
    Southern Cal
    That's helpful thanks. So maybe I check for voltage on the heater wires? And the heater should turn on at cold start?
  5. Tombukt2
    Tombukt2 Senior Member
    13,110
    2,352
    Durham NC
    Check continuity. Ohms .
