Persistent P3013
Discussion in 'Gen 2 Prius Technical Discussion' started by dubseven, Jun 27, 2019.
  1. dubseven
    dubseven Junior Member
    Denver, CO
    Redoing the battery pack in a 2011 RX450h (not exactly a Gen2, but super similar, hoping y'all can help). Car has a persistent P3013 cell block 3 weak. I discharged/charged all the cells, they are all around 5ah, no weak cells, but the pack was WAY out of balance. Put it back together, still getting a P3013. Thought it could be the battery sensor module, replaced that with a brand new one, still no dice. Any advice?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,230
    5,931
    Columbia, SC
    Does this have the 9.6 volt modules? Are you certain you worked on/checked Block 3? What methodology did you use to discharge/charge them? How many times? What were the results? Unfortunately, I've seen plenty of "around 5ah" module that are experiencing a single cell failure, but the other cells hide it when you only look at overall Ah. The voltage graph during the discharge tells a lot of info also. If you're seeing any of them drop ~1.3 volts fairly quickly, then hold steady, that's a solid indicator you have a bad/weak internal cell.
    strawbrad likes this.
  3. dubseven
    Denver, CO
    Yes the 9.6V modules. Yes, I discharged and recharged each cell individually. 1A discharge, 1.5A charge. 5-10 cycles per cell.
  4. ChrisFaehrtPrius
    ChrisFaehrtPrius Junior Member
    29
    Hamburg, Germany
    i'm guessing you already cleaned the corrosion off the connectors, if any?
  5. dubseven
    Denver, CO
