PG&E TOU Plan/Thermostat Rebate
Discussion in 'Environmental Discussion' started by iplug, Oct 21, 2020.
  1. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
  2. hill
    8,159
    Below is a benefit of having 8KW AC rated PV. Nevermind the prehistoric central AC dinosaur that refuses to die, the downside of a loved one, working out of the house, with menopause ... resulting & feeling hot - even at 70°f, means the thermostat is set more akin to running a meat locker. Let the (loosing) battle of thermostat control continue!!
    With dynamics like that, TOU, although it works for many, was quite the unsuccessful experiment. The only thing many won't try is where you relinquish to the utility company, the right to run your AC on the hottest days when it's most likely to cause a brown out. Misery loves company.
  3. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    Sounds like you need Powerwalls and maybe a brand spankin' new, super efficient central heat pump when the dinosaur goes extinct.:D
    hill likes this.
