phantom clarinet toot
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, May 18, 2010.
  1. bwilson4web
    16,010
    It has been nearly a year but I still hear it. Between POWER and the engine coming on, I hear one, brief, faint 'toot' that sounds like a clarinet ... perhaps a B or B-flat. I keep thinking about recording it if nothing else to verify the pitch and measure the duration. But I kept waiting for someone to start a thread about the little toot.
    Has anyone noticed or possibly researched the little startup toot?
    ps. Gawd I hated to start this thread.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. johalareewi
    johalareewi Member
    393
    44
    uk
    Will have to listen out while I do my pre-flight checks :)
  4. Politburo
    Politburo Active Member
    971
    208
    B or B-flat... in which register?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Are you sure it's not a Concert A? Maybe your Prius needs a tune up.
    Tom
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    You might want to stop the lunches at Taco Bell.
    :eek:
  7. Prius42
    Prius42 New Member
    139
    Maryland
    You knew the replies were going to be like this... Anyway I went out and tried it a couple of times (unusually without kids) and I hear some relays clicking, sometimes the rumble of a pump, a beep from the Nav and then the Nav DVD seeking a bunch of times and then the ICE starting up. I don't hear anything that I would describe as a "toot". Does it happen every time? Could it be the CD player or Nav seeking? Can you go try another car at the local dealer? I had a loaner for a couple of days which was great since I could verify that all the things my Gen III does seem to be normal, or at least not confined to my car.
  8. bwilson4web
    16,010
    The "toot" isn't consistent. It seems to happen when it is warm outside and the car has been sitting for a while. I'll try to record it and share the MP3 clip.
  9. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Fuel system dealing with air/vapour pressure? Sometimes those valves will emit noises, and every one is different. I know the GIII has a convoluted system to control emissions as it doesn't have the bladder.
    Sometimes Pearl emits strange noises when the fuel system changes state (car on/off cycle).
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    You obviously, unknowingly got the Zamfir upgrade.
  11. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    could it be the climate control system? like a vent purging/opening? I've heard it too, and thought it was coming from the underdash area like where air vents would be located.
  12. Politburo
    971
    208
    Since you mentioned it happens when it's warm, and finman suggested the climate system..
    If you switch to recirculation in the GenII, it makes an odd sound that typically can only be heard stopped with engine off and windows up. I wouldn't personally call it a clarinet sound, but it's close enough. It lasts for about 1-2 seconds.
  13. bwilson4web
    16,010
    You've got the area correct. I always look to the driver side vents when it happens. If it wasn't for my curiosity, I'd just laugh and tell the wife, "Well no more <whatever I didn't like> for dinner." <GRINS>
  14. johalareewi
    johalareewi Member
    393
    44
    uk
    Perhaps there's a jazz pixie trapped behind the dash?
  15. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I've heard this too. But in my case, it sounds more like an oboe.
  16. bwilson4web
    16,010
    Found it! Sony Erricson cell phone in shirt pockiet. Apparently the cell phone announces it has found a bluetooth friend with a little toot. Since it is in my shirt pocket, it seems to come from from the front left.
    What happened is I thought to record the toot with the cell phone, MPEG camera. Only it flashed a screen message instead of making a noise but the timing was right. So I closed it, held it to the right, and power cycled the Prius . . . the cell phone tooted.
  17. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I once spent an hour at four in the morning looking for the source of a beep around the house. I thought it was the alarm system or a smoke detector. Turned out to be a low cell phone. I would like to make a list of everything we own these days that beeps:
    Cell phone
    Microwave oven
    Clock
    Computer
    Smoke detector
    Watch
    Bread machine
    Car (many beeps!)
    Answering machine
    Carbon monoxide detector
    Door bell
    Cordless phone
    Digital thermometer
    I'm sure I'm missing a lot. Any more?
  18. Prius42
    Prius42 New Member
    139
    Maryland
    Wow! That was certainly a twist. I don't think anyone was going to help you find that. At least the exercise of trying to explain it to others helped you figure it out!
  19. RedBackFur
    RedBackFur Owner
    109
    San Leandro, California
    Rice Cooker
    Wall Oven
    Iron
    Clean-Sense DIB 1500RW Toilet Seat Bidet :redface:
    Digital Camera
    Air Conditioner
    Alarm System
    Scanner/Printer/Fax
    Remote control Ceiling Fan
    Dish Washer
    Digital Camera (One of them Meow's when you fire it up)
    Roomba®
    CPAP :yawn:
    Uninterpretable Power Supply (UPS)
  20. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Glad you uncovered it. The next step would have been to provide gps co ordinates along with some map locations and pictures showing exactly where the toot occurs and try to recreate it. The temperature and relative humidity would also help. Thanks :D
