PHEV in Canada
Discussion in 'Prius PHEV Plug-In Modifications' started by dek1234, Aug 13, 2011.
  1. dek1234
    dek1234 New Member
    17
    Rouyn-Noranda, Québec, Canada
    hi
    i am in Québec Canada, i have a 2008 prius and i want to convert it to a plug in prius.. where can i find a "shop" to convert my car?
    thank you.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    What kind/brand of conversion are you considering?
    If you are considering Enginer, the closest installer seems to be in Ottawa.
    See Enginer's installer page for more info. http://www.enginer.us/installers/
  3. ericbecky
    4,365
    3,209
    Madison, Wisconsin
  4. dek1234
    dek1234 New Member
    17
    I am a hybrid taxi driver , idrive about 150 km per day, what conversion do you suggest me?? ithought there was only one conversion possible!!:eek:
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    If you drive 100 miles a day or so, you'll probably want a 10kwh system, unless you have many hours each day where the car is not being driven to charge it up again (like a normal worker who can plug it while they sleep at home and while they work at work)
    How many hours a day is the car in use? 10kwh systems take 6-10 hours to charge so most likely the taxi can only accept one full charge per day, or less.
  6. Mendel Leisk
    38,247
    Just uneducated 2 cents, and assuming you only recharge overnight: the longer your daily driving, the less the battery will help, and the more you will be carrying the deadweight of the extra batteries. You could do a spreadsheet to compare with/without, but with a battery range of say 20km, and daily driving 150 km, I don't know that you would ever recoup the expense. And the added complexity, possible problems?
  7. dek1234
    dek1234 New Member
    17
    thanks for the comments!!!
  8. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Although he's in London, I believe GrumpyCabbie has an Enginer conversion. You may want to PM him to get his experience/suggestions.
