Phoenix tech's or DIY'ers?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusMonkey, Jan 6, 2020.
  1. PriusMonkey
    PriusMonkey Junior Member
    Arizona
    Hello all,
    Not sure if this is allowed here so i apologize. Check engine light came on. From the codes I've been told showing Ignition coil misfire. I recently replaced the spark plugs mid 19'. Wondered if there are any techs or DIY'ers who may be able to help diag if infact that's it & which. Rather not replace them all if I don't have to. Also looking to drain the fluids & replace. I have all the fluids just not the tools. Moving soon & rather not buy more stuff. Thanks for any help/info!
  2. Eddie25
    Eddie25 Active Member
    369
    137
    IL
    One quick thing to consider is where did you get your plugs? They seem to be a heavily counterfeit item and caused problems for me in 5 months. I know it sucks to check the plugs on these, but might be worth it.
    PriusMonkey and bisco like this.
    49,478
    how many miles on her?
    PriusMonkey likes this.
  4. JC91006
    16,482
    8,399
    If you can't DIY this yourself, you can try and contact Steve at phoenixhybridbatteries.com and he can possibly help you with this issue. He's a battery guy but he knows his way around the Prius
    PriusMonkey and Raytheeagle like this.
  5. PriusMonkey
    Arizona
    175k
  6. PriusMonkey
    Arizona
    Bought the denso spark plugs off ebay.
  7. bisco
    49,478
    those might or might not be an issue, a lot of fake plugs on ebay.
    have you ever cleaned the egr circuit?
  8. Eddie25
    369
    137
    IL
    It's your plugs.
  9. JC91006
    16,482
    8,399
    Did you buy the correct Iridium plugs? Maybe you should take them out and take a look, maybe it could be loose if not torqued properly
