Phones that are too big for wireless charging
Discussion in 'Gen 4 Prius Audio and Electronics' started by raspy, May 8, 2017.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    Just got a Samsung S8+ and it doesn't fit flush in the wireless charging pad, it's too long.
    Just wanted to share in case it helps others. I found that it stops charging sometimes and I have to switch it on and off again (wireless charging, not the phone) 1494280797021.jpg
    Tideland Prius and RCO like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'll pass on the S8 then. I'm only up to S2, so got a bit to go to catch up!!
  3. Prodigyplace
    12,671
    11,829
    Central Virginia
    The S8+ model is the large one. The regular S8 is smaller.
  4. alanclarkeau
    7,045
    7,593
    Small will be big enough for me. I just use it a bit for email etc while I'm away from home. I understand it makes phonecalls too.
    I need to work out how to use it as a music player - the car tells me that it is connected as an audio device, but no matter where I've saved MP3s, the car can't find them.
    RCO likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It might work better the other way round (top to bottom).
  6. raspy
    raspy Senior Member
    438
    699
    London, UK
    I'll give that a try.
  7. GlennCocoBad
    GlennCocoBad Junior Member
    Pasadena
    Four Touring
    Yup doesn't charge my iPhone Mophie case either, too big to lay flat.... HUUUGE waste :/
  8. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    Thanks for sharing! Oh well. You won't have to deal with the efficiency losses of wirelessly charging your phone with the traction battery, which was charged with a 40% thermal efficient combustion engine, or regenerated from potential energy. :D
    RCO likes this.
  9. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Very iffy to work with my older Motorola Nexus 6 as well. I have a ballistic case and it has a curved back. Shedding the case gets it to kind of charge but very slow. It has been my experience that wireless charging in general doesn't work all that well.
    RCO likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Agreed it's not ideal, except just to charge the phone rather than run any apps while doing so.
    #10 RCO, Aug 28, 2017
    kithmo likes this.
  11. flic
    flic Junior Member
    IT
    I have a Samsung Note 3, it is not native for wireless charging. But with few euros I purchased a coil to be connected in the rear side of the phone between the battery and the cover... and it works!
    RCO likes this.
  12. Frederickdawg
    Frederickdawg Active Member
    596
    336
    Florida Unfortunately
    Wife's Note 8 has to be precisely placed else it won't charge wirelessly. Shame the designers of the Prius didn't think phones would get bigger.
    SM-N950U ?
    Ty D likes this.
  13. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    So how about the S10+ which is a couple of mm shorter?
  14. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    My Samsung Galaxy S8+ phone fits and charges fine in my 2019 Prius XLE, even in its large Otterbox Commuter Series case.
  15. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    S10+ is working fine for me even in it's case on the charging pad. Only problem is it runs a lot warmer than the other charging pads I have so I'm really only charging it when I have to.
  16. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Just tested the Galaxy S9 that my wife has and it works nicely on the pad and there is room to spare. In about two weeks I will be getting a iPhone XR from work and I will see how that works. It has the added problem of a Otterbox case which increases the distance from the pad to the coils in the phone.
    My car is a Corolla though, I will measure the pad tomorrow and post the measurements here to see if there is a difference in the sizes of the pads between the Prius and the Corolla.
