Photo explain
Discussion in 'Prius c Main Forum' started by Pools, Jul 23, 2019.
  1. Pools
    Pools Junior Member
    New zealand
    Can someone explain to me how I should be reading this display. I'm more interested in the fuel costing part.
    Thanks in advance.
    49,489
    welcome!
    no idea, but i'll take a whack at it. you don't have the correct fuel cost input. the manual should specify how to update that.
    then you will get the correct cost when you fill up
  3. michael.sfo
    michael.sfo Member
    52
    42
    San Francisco
    2015 Prius c
    When you fuel up, you can input the price per gallon (the system prompts you automatically when you turn the car on after filling the gas tank). When that is input correctly, you will get a correct value for "fuel cost from start" (fuel expended since the most recent time you turned the car on) at the bottom right corner. The triangle indicator on top of the horizontal bar shows how your current driving performance is costing you in terms of dollars per kilometer. The further to the right, the more expensive it is.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    What michael said up there. To be honest though, if you ever use it, you'll notice it ALWAYS ends up around 5 cents per gallon making it a pretty worthless.
