Photo- what is this called and does it matter if its broken?
Discussion in 'Newbie Forum' started by Cynthia Buckles, Nov 22, 2018.
Tags:
  1. Cynthia Buckles
    Cynthia Buckles New Member
    Hawaii
    [​IMG] [​IMG]
    changing brakes for the 1st time following you tube. Noticed this broken rubber piece above the brakes. 169,000 miles on 2004 Prius.
    Does this matter? What is the function of this piece, what is it called, how difficult is this to fix, and how high of a priority is fixing it?
    Thank you for any info
  2. Cynthia Buckles
    Hawaii
  3. Cynthia Buckles
    Hawaii
    49,511
    looks like a dust boot for the strut. unless they have been replaced, it might be just as easy to do them both at the same time.
  5. Mendel Leisk
    38,738
    The shock itself looks to be in good shape. There was a thread on this subject not long back, and I think the concensus was to patch it back together, say with some small zip-tie "stiches", then some tape over to make a bit more secure and help it in it's function, which is as a dust shield.
    Another option: there might be aftermarket split boots that you can put on? Not sure.
    It's a big/expensive hassle to replace the boots, and I think most who do it replace the shocks at the same time?
