PHV-45K service, what should be done?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SlidingBike, Mar 26, 2019.
Tags:
  1. SlidingBike
    SlidingBike Active Member
    171
    112
    Fremont, CA
    My PHV is up for 45 Service, the Service reminder is flashing on my face on the dash.
    • I have changed both Engine and Cabin Air filters a week back,
    • I am close to go for the next oil change(1K miles away).
    • I got Life time Wheel Alignment deal, few months back tires are balanced. Tires are said to be in good condition.
    • Nearly 2+ months back got the fuse recall done at the dealer, they did a complimentary multi point inspection, which said all good.
    • Now when I go for oil change, my mechanic(I dont go to dealer to make them rich off poor population), he will check all fluids and breaks etc.
    Having said that, what else do I need to get done for 45K?
    BTW, the TPMS light is coming for few days and going off and after few days its coming again, how to understand this? ( Of course, I will get this checked on my next oil change mechanic visit but I do I need to be worried about this now?)
    Thanks in advance.
  2. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    You might consider setting the pressure on all tires and then resetting the TPMS system as described in the Owners manual. Page 483 in owners manual for 2015 PIP. A button under steering wheel initializes pressure after you set pressure in tires.
    #2 CraigCSJ, Mar 26, 2019
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Since we no longer have full service gas stations it's up to the owner to check oil level and tire pressure. Weekly is a good practice.
    The TPMS light is probably coming and going because the tire pressure fluctuates with temperature and at least one tire is just low enough to be at the threshold. Which is the whole purpose of the TPMS. Check your tires right now and pump up any that are below the recommendation on the label in the driver' door opening. Most of us actually keep ours well above that. Up around 40 psi is quite common. I wouldn't go any higher. I might add, check that low tire for screws and nails.
    SlidingBike and Raytheeagle like this.
  4. SlidingBike
    171
    112
    Fremont, CA
    Thank you @CraigCSJ and @jerrymildred , I will try that. Usually I get my nitrogen pressure at Costco, will inflate'em as suggested and check.
    jerrymildred likes this.
  5. jerrymildred
    11,508
    14,109
    Tampa, FL
    Didn't know you were using nitrogen. That does complicate things a bit.
  6. bisco
    49,402
    good time to think about tranny fluid. your car is just broken in, nothing beyond filters and oil until at least 100k.
    keep a weather eye on your 12v.
    SlidingBike likes this.
  7. SlidingBike
    171
    112
    Fremont, CA
    Thanks @bisco for additional care check points. I will discuss the tranny fluid with my mechanic (if required I will get it done too).
    I plan on keeping this car at least till Dec 2021 (thats when my CA HOV decals would expire), I may find another similar vehicle in Toyo/Lexus fleet :)
  8. Mendel Leisk
    38,668
    Do you have the Warranty and Maintenance Booklet?
    Basically, rotate the wheels and visually check the brakes.
  9. SlidingBike
    171
    112
    Fremont, CA
    @Mendel Leisk Many thanks for the above reference, I should be having this booklet in my car glove box, will check. I guess I need to get the tires rotated beyond those previously discussed check points.
  10. Mendel Leisk
    38,668
    I've been getting all our tires at Costco, nitrogen fill, but just top them up with regular air. The first top up usually happens within hours of purchase; I like to have them a little higher. I use to swing by the gas station for air, now I just use a bicycle pump, one of those floor-standing models.
    If the TPMS light is going off the obvious first step is to check your tire pressures. If that's done and the light's still going on. In that case maybe a dying battery. The easiest thing to do is ignore it, at least till you're getting tire replacement.
    A few years back we had the TPMS light go on. I pulled into a gas station and raised all pressures 3~4 pounds, and the light went out. Later I dropped the pressures back to my usual, and the light stayed off. So maybe there can be communication errors.
    #10 Mendel Leisk, Mar 26, 2019
  11. jerrymildred
    11,508
    14,109
    Tampa, FL
    I find the PDF manuals much handier. In fact, the original owner of my Prime apparently didn't even hand them over when he/she relinquished the car. Get the PDF versions for free from Toyota. Toyota Online Owners Manuals and Warranty
  12. Mendel Leisk
    38,668
    Yeah, Toyota Tech Info too, has them all. Our paper manuals are all ensconced in the glove box, but pdf is what I usually go to. Ditto for our kid's cars.
    My one bug bear: the manufacturers REALLY should release the Repair Manuals (aka Shop Manuals), stop bogarting them behind a paywall. If one does it, it would be a real tug for the DIY crew...
    Honda at least shows stuff like the oil change in their Owner's Manuals, commendable.
  13. bisco
    49,402
    if you're only keeping it 2-3 more years, and under 100k, i wouldn't bother with tranny fluid, unless you want to do it for future owners. it should be around $100.
  14. Mendel Leisk
    38,668
    Having done 3 transaxle fluid changes, the first drain, at the one year mark and around 15K kms, was by far the darkest.
  15. SlidingBike
    171
    112
    Fremont, CA
    TPMS issue is gone so far after properly inflating the tires. Thanks for the suggestions.
    I didnt think of this basic work around as I had my wheels aligned recently and thought the pressure is verified at that time.
