PHV charging power draw
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, May 10, 2011.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Any idea on amps drawn while charging PHV?
    Should charging outlet be on separate circuit?
    Any recommendation on extension cord gauge and max length?
    thanks,
    Bill
  2. drash
    drash Senior Member
    2,476
    1,251
    Upstate NY
    Maybe Ken1784 or pEEF can answer and correct me if I'm wrong, but Toyota FAQ for the PHV says : "The Prius Plug-in draws approximately one kilowatt and takes approximately three hours to charge", and from that we can make guesstimate of about 12 to 14 amps depending on circuit voltage. While it would seem any 15AMP circuit might be able to handle it, I would put it on it's own 20AMP breaker if were me. Seen too many circuit breakers burn up.
    :eek:
    Also if you had a 240V line it would only take an hour and a half.
  3. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    If it draws 1 kW, it probably only draws 8-9 amps, or about the same as your average microwave oven.
    This is probably a good engineering decision considering the smaller pack, and all the bad wiring that exists. I would charge on a GFCI outlet to be safe.
  4. crewdog
    492
    388
    Woodstock, GA
    Thanks for the replies.
    Putting PC and laser printer on separate circuit upstairs has made life easier, and good idea about the GFCI.
    I think it will be a lot less expensive to just do separate 120v circuit breaker than run a 220v line. when thinking about daily driving habits, it seems there's very few times Prius is in garage for less than 3 hours.
  5. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
  6. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I followed the links to http://www.georgiapower.com/pricing/files/rates-
    and-schedules/2.30_TOU-PEV-1.pdf and it is TOU.
    Excerpt:
    MONTHLY RATE: Basic Service Charge $9.00
    Energy Charges:
    On-Peak kWh….........19.2948¢ per kWh
    Off-Peak kWh……….5.8295¢ per kWh
    Super Off-Peak kWh...1.2500¢ per kWh
  7. tmcgee
    tmcgee New Member
    Thanks for all the info in here guys
  8. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    The numbers do not make sense. If it takes 1 KWH of charge, and it takes three hours to charge, you are putting in 333 watts per hour. That out of a 115 power line should be ( Power = Current x Voltage ) around 3 amps. Homes can power 10 amps out of a standard sockets, so why would they not charge at a faster rate? They would not need a 240 charger option.
    Something is missing from the information.
  9. drash
    drash Senior Member
    2,476
    1,251
    Upstate NY
    Yeah you're splitting 1KWh up into 3 hour segments. Its 1 Kilowatt per Hour. The 240V option is the same 8 to 9 amps at 240V so it only takes 1 1/2 hours.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Kilowatt is power.
    Kilowatt-hour (kilowatt * hour) is energy.
    The draw is 1 kilowatt (8.3 amps @ 120 volts).
    Charging for 1 hour therefore gives 1 kilowatt-hour.
    Charging for 3 hours gives 3 kilowatt-hours.
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    It is one kw*hour per hour.
    Your mistake is a common one. Power per time does not have a practical meaning. OK, maybe in flux capacitors ;)
  12. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Okay...I went back and read the Toyota page better.
    They said it takes one kilowatt for three hours..duhhhh thats 3KWH of energy..
    That works out to about 9 amps draw...around the max for a normal wall socket.
  13. hill
    8,153
    Get your self one of these fine tools:
    Find both legs of the 120V that the 240 volts delivers to the different circuits, and BOOM, you're re-charging your EV or PHEV in 1/2 the time.
    That's what I do when I'm away from the hard wired 240v EVSE at home. The power supply in most of the 120v J1772 oportunity pass-through charger cables, that come with PHEV's can be changesd out to a switching power supply (so they can run on 208v - 240v or 120v). PC member pEEf has a link here on PC, so you can get that done to your 120v portable EVSE. Then simply google "quick 220" and you'll find the seller/manufacturer of the quick 220 appliance ... if you don't have an actual 240v outlet. They're great!
  14. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    120 V wall sockets are generally rated for 15-20 amps. So let's say 15 amps, times 80% for a continuous load = 12 amps max continuous load.
    (I do note that 1500 Watt heaters are commonplace for 120 V plugs = 12.5 A continuous.)
