Physical Key - Battery Disconnect
Discussion in 'Gen 2 Prius Main Forum' started by prairiecomm, Aug 22, 2011.
  1. prairiecomm
    prairiecomm Junior Member
    Iowa
    We disconnected our 12V battery in order to reset the check engine light (went on driving at high altitude w/ 87 octane). Locked the car, came back the requisite 20 minutes and can't open the driver's door with the physical key. Argh!!
    We understand it should turn a short way, then require considerable force, tho not necessarily pliers. A little nervous about using pliers to force it ... suggestions?
    We're pretty sure we tested the key when we bought our used 2008, but can't remember. Should the key be 'reversable' ie, go in either way?
    Anyone familliar w/ Seattle Toyota?
    Thanks,
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You have to turn and hold the key in the unlock position while pulling the door handle to open the door.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Ditto this. You turn the key all of the way, and pull the door handle while holding the key turned.
    Tom
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it takes force with the 12v disconnected. it should be hand force, not plier force.. all depends on your hand strength really...
  5. fuzzy1
    10,140
    So you are in my region now? Sorry, I haven't used that shop.
    But I hope you are not saying that the check engine light was caused by using 87 octane fuel at high altitude. That won't happen anywhere in this state, or in any neighboring state. And probably not in Colorado either.
