Pics of Hottest/Coldest outside temp
Discussion in 'Gen 3 Prius Fuel Economy' started by Much More Better, Feb 23, 2010.
  1. Much More Better
    Much More Better Active Member
    655
    163
    This is why mpg sucks right now. Maybe some Aussies can post some searing temps.
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    We've had a light Winter. I haven't had to deal with temps that cold. We can usually count on at least one -21c (-6f) morning per Winter.
  3. User37
    User37 Can spell PRIUS
    83
    Italy
    Here is one slightly offtopic. ;)
    A VW Polo, the little brother of the Jetta TDI. Last summer in Sardinia. 46C is around 115F, or so, if I get my math right.
    Consumption is comparable to a Prius but the dimensions of the car are smaller.
  4. Tideland Prius
    16,665
  5. Much More Better
    655
    163
    Tideland: Sweet!!!!! When did you get that pic?
  6. Tideland Prius
    16,665
    When we hit rock bottom (-46.5°C). I wasn't up early enough (that was taken at 7-8am) to catch it. Well I took two shots I guess... since the darker shots would've been closer to 7 and this brighter shot would've been when the sun rose.
    Oh and it was taken in Dec.
    Of note... the manual said the range for the display is -30 to +50°C :confused:
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    -40! That shouldn't be allowed.
    Where in Canada are you?
  8. Much More Better
    655
    163
    I guess you park outside?
  9. TonyPSchaefer
    14,816
    2,501
    66
    "What's the temperature?"
    "Negative 40 degrees."
    "Is that Centigrade or Fahrenheit?"
    "Yep."
  10. Tideland Prius
    16,665
    Thankfully, not that morning. I actually woke up and drove out to capture this pic knowing it's one of those things that happen once every few winters.
    lol @ Tony.
  11. 924danimal
    924danimal New Member
    31
    College Park, MD
    Temperature? That's more like a lack of temperature. :eek:
    Too cold for me.
  12. vday
    vday Member
    312
    Israel
    It just happens that negative 40 Centigrade and fahrenheit are the same
  13. moner
    moner New Member
    302
    59
    Vancouver, BC
    Truly disgusting, SO glad I live in the warmest part of Canada.
    This is the hottest I've seen in my Pri so far, hoping to top it on my road trip to Death Valley in April!
      File size:
      107.6 KB
      563
  14. Tideland Prius
    16,665
    Much More Better, looks like you have your two extremes :D
    oooh... I'll bet on.... 42°C :p
    I believe that's the "Yep" in his post.
