Picture needed: Ignition coil
Discussion in 'Gen 2 Prius Main Forum' started by tallen, Nov 2, 2008.
  1. tallen
    tallen New Member
    Off the wall question, but does anyone have some decent pictures of the coils on a prius? I am having a heck of a time finding any. Much appreciated! :rockon: I was looking at specs of them, and they seem like a good choice for a project car because I have very limited room and they are quite powerful. Thanks to anyone who can help.
  2. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Prius uses a direct ignition system.
    Ignition coils are are placed just above each spark plugs.
    Ken@Japan
  3. tallen
    tallen New Member
    Quite aware of it being a COP. Pictures?
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Google image it.
  5. tallen
    tallen New Member
    Well, I have decided to give them a shot. The dwell, etc looks spot on. Does anyone per chance have the wiring diagram as it goes into the coil?
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    The coils have plugs on them. each wire is a different length, so you can't mix them up. each plug is held in with 1 screw. only hand tighten this screw when re assembling. as others have said, they sit right on top of the spark plugs. not extremely snugly either.
  7. tallen
    tallen New Member
    Huh, did you read my post? I don't own a Prius...........:confused:
    Anyway, anyone with a pinout for the coil (in the haynes or manual cd) please post up the pinout!
  8. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Wouldn't you be better off using an LS1 style coil? You can get them from Accel or others, and for the price of one Prius coil you could probably get 6-8 LS1 style coils
