Piece fell from passenger side. car started doing a lot of noise.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by wilson_h, May 11, 2015.
  1. wilson_h
    wilson_h Junior Member
    Panamá City, Panamá
    Hi everyone, i wanted to ask you guys about something that happened recently
    one day, while cleaning the car, i found this little piece at the passenger side, under the carpet.
    probably it went under the carpet and is from some place in the dashboard since i cannot find a place for this piece.
    anyway, after i found this piece, the car has started to do some clanking plastic noises as if a plastic piece is clashing with something in the glove box or above it. i guess this piece does something there and is the cause of this.
    i don't know where this piece goes and if any of you could help me i would be very thankful.
    thanks a lot for the help.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It's the plastic nut from the kick panel in the footwell. Look in the forward, lower corner of the footwell kick panel and you will see where it came from. ;)
    wilson_h likes this.
  3. wilson_h
    Panamá City, Panamá
    thanks a lot! will look and tell you how it went.
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    When did you get a c? (Should I be congratulating you on your new purchase)? How did you know that????
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    I didn't get a c. ;)
    But these cars are put together with similar pieces.
