Piece fell off? my front bumper
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by William Collins, Dec 22, 2020.
  1. William Collins
    William Collins New Member
    A small panel cover fell off my Prius V Four bumper just above the right fog light. I have no idea how this came off unless it was taken off at my last service and not replaced. What does this cover up and what does it cost to replace?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,512
    6,597
    Texas Hill Country
    It is the towing eye bolt cover. It is meant to come off when a tow truck driver uses the screw in tow bolt that is with your spare tire.
  3. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    Above is the answer as to what it is ... don't forget to order the "string" retainer.
    Not sure how the cover and retainer fell off... could of had a broken clip from prior removal, yet the missing string is odd, implying someone was "in there" before.
    You can search for price, yet I think the part arrives not painted.
    That could add to the cost.
    As an option, paint or wrap both sides in the color black.
    Good luck, easy to install.
  4. Mendel Leisk
    41,904
  5. ChapmanF
    18,547
    No separate "string", it's just molded as part of the tow eye cover itself. You can spot it (if you squint, black-on-black) in images that show the cover from behind.
    You can see it just has a barbed end on it, you pop it through that tiny rectangular hole you can see down in the corner of the opening in the bumper.
    I am not sure that part number/picture is exactly right for your v (the shape of the entire cover seems too square, and the retainer seems to come from the wrong corner) but it gives you the idea.
    Is this by any chance an alternate or aftermarket bumper cover?
    #5 ChapmanF, Dec 23, 2020
  6. Mendel Leisk
    41,904
    Just a tip: a pen knife blade slipped in the gap is gentler/better than screwdriver, for finessing that thing out. The gap is pretty tight, and screw driver may chew things up.
    I dread to think of the tow truck driver's technique, lol.
