pinched gasket, oil everywhere
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by john1701a, May 8, 2013.
  1. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    I took my Prius in for a free oil-change & tire-rotation. Last time, they overfilled. The oil was 1/2-inch over the maximum mark. That's frustrating. I was obviously going to check this time. To my surprise, it was perfect, just a little under maximum! Cool.
    All but the last 10 minutes of my driving that day was on electricity. So, the engine had it pretty easy. But with the pouring rain coming down, I didn't notice anything... until the next morning.
    The garage had slight oil smell. I wanted to double-check the fill level anyway. The oil was at the minimum mark. Huh? I tried again. Same thing. Oh! Oh! Sure enough, I backed out of the garage to discover a large puddle of oil. Grrrrr. Fortunately, I wasn't stranded anywhere and the engine was just fine.
    Within about 20 minutes of calling the dealer, they had a mechanic on his hands & knees cleaning up the mess in my garage. We then jumped in the Prius and drove to the dealer. Only needing electricity to drive there made that part really easy.
    Needless to say, they were extremely apologetic and very attentive. Gotta like that. I enjoyed getting to chat with the mechanic for awhile too.
    Long story short, the gasket (that rubber ring you replace each time) had been pinched. That allowed oil to squirt out. I lost almost all of it in just a matter of minutes.
    Be attentive of this when changing oil yourself. Also, be aware that the shop could mess up too. This is a very, very good reason to check the level afterward. Mistakes happen.
    F8L likes this.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Wow! If driven using the engine w/dangerously low oil, it'd probably would've been bye bye engine.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    The mechanic over tighten the nylon gasket, it happens especially when you're not careful on how tight you tighten it.
  4. Ridder
    Ridder Member
    141
    51
    Netherlands
    What gasket are we talking about?
    The filter gasket?
    Drain plug gasket ? (that's normally a metal ring....do not know about the Prius....on my previous car (Mercedes) they never use d the drain plug, just sucked out the oil)
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    This exact error occurred with my CTh, only I was the one who pinched the gasket. The thing is, though, I know better than to over tighten so it may be a poorly seated gasket that is the root problem.
  6. john1701a
    12,797
    5,280
    57
    It was the gasket for the paper filter canister, that rubber O-ring.
    Fortunately, there's no way to over-tighten with that new design.
    Unfortunately, the O-ring could have issues if you aren't careful... which is what happened on mine.
  7. NutzAboutBolts
    1,601
    1,691
    Bay Area
    Well the mechanic is bad, there is no way for that o-ring for the filter housing to be pinched if you put it in the groove. He probably put everything in too fast for it to be pinched when putting it in. It never happened to me before, but it does happen to people who aren't thorough with their work. Glad they fixed that issue for you and apologized.
  8. john1701a
    12,797
    5,280
    57
    5 months later, I took the Prius in again for an oil change. With the free changes used up, I would normally do it myself. But there was fallout from that incident back in May...
    The mess from the oil was bigger than I had thought. It eventually all dripped down and got soaked up by the blotter on the plastic door under the pan. That caused it to sag, exposing a breath-hole to catch spray, which contributed to even more sagging. That reduced ground-clearance and would clearly become an issue in deep snow later. Needless to say, there was an obvious problem they directly caused.
    To my pleasure, they replaced the entire plastic section without question or charge. That was a nice follow-up to a situation which could of had a very different outcome.
    I sure hope no one else ever has to deal with the same thing. But at least they'll know there are some service departments willing to acknowledge mistakes and do what they can to rectify them.
  9. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Minnesota is too far for me to drive for an oil change :p
    Glad they took care of you and as you said, there are plenty of good service departments around who take the time to care for your vehicle. Finding one, on the other hand, is a PITA.
  10. bisco
    51,148
    i have never heard of that kind of service! it almost makes up for their poor craftsmanship.:cool:
  11. El Dobro
    El Dobro A Member
    7,075
    3,258
    And that's why I always do my own services, free or not.
