Pink crust coolant leak?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Syed Ashar Ali, May 21, 2023.
  1. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    83
    Houston, TX
    2014 Prius c
    Hi I changed my hybrid battery today and the guy said there is pink crust on the inverter coolant so that means it's a leak.
    Just wondering if there's any truth to that?
    Should I get it replaced?
    52,386
    1) you are in the gen 4 forum, are we talking your prius c?
    2) idk what 'pink crust on the inverter coolant' means?
  3. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Pink crust and residue is evidence of the pink long life coolant leaking yes. Was your coolant low?
  4. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Oh sorry wasn't aware of different prius thread. Not too good with cars but I'll explain it the best possible way. Yes it's 2014 prius c
    I did a fill and drain on the OTHER coolant 5 months ago. The one closer towards the steering wheel. The coolant closer to the opening of hood I never did a fill and drain.
    I'm not sure if it was low. But he saw pink crusts around the cap area of the coolant. He said he will fix it later. I can still drive it.
    Later on he said he can't find neck filler coolant part. Something along those lines. Can't remember the exact words. He said maybe the clamp is just lose so he will just replace the clamp and do a full and drain on the coolant ClOSER to the opening of hood and change spark plugs.
    I have 172,000 miles.
    He said you should fix the crusty coolant leak or your car can blow up but said it's fine to ride it now
  5. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Should I be concerned
  6. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Yes a coolant leak can lead to engine overheating and unrepairable damage.
    If it's just around the cap and there's no loss of coolant I'm not sure if your problem is as dramatic. I'm not familiar with the Prius c but do you think they share the same coolant? Could you have overfilled when you flushed your coolant? If it overflowed that can explain crust around the cap. It's not totally harmless you did have some pretty corrosive stuff splashing around but there may not be a leak.
  7. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Well i did not do the fill and drain on the coolant CLOSER to the steering wheel one. I'm not sure if both coolants share the same thing. A mechanic shop that deals with hybrids did it. When they gave me the car back I noticed the coolant level was right at the minimum or average line. It wasn't completly filled
    I asked him if I myself can top the coolant. He said yes. So I topped it all the way up.
    Yes its just around the cap.
    Can I drive another week or so before getting this fixed?
    Can any mechanic shop repair this or does it have to be a hybrid specialist?
  8. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Any shop can do it, but it is best to use Toyota's long-life coolant.
  9. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    So... To fix the pink crust around the cap it needs to be drained and filled and that will solve the leak?
  10. Mendel Leisk
    41,898
    Could be they just spilled some when refilling. Where exactly is the pink crust; post a picture?
  11. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Coolant expands when hot and the tank you see under the hood is more akin to overflow. When cold it should be between the low and high lines. Likely, if you filled it to the top you just overfilled and it expanded out of the cap, leaving the residue.
    From what you've described I don't think you have a leak but just had some overflow. What kind of repair is this guy suggesting anyway?
    Keep an eye on your coolant. Check under the hood every drive and see if it's losing any. See if there is any more pink crust under where you normally park. If you see an overheating warning stop immediately and turn off the car. Get a tow. But I'm doubtful it'll come to that
  12. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    The guy is suggesting to fill and drain the coolant closest to the opening of hood. ( I did a fill and drain on coolant closest to steering wheel 5 months ago)
    He is also suggesting to put new hose clamps on
  13. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    Well at the age and miles of your car that's probably not a bad idea regardless. Hoses and clamps can degrade over time and since you already did a coolant flush on the other reservoir it's probably time for that one too. Its probably fine to keep driving if you haven't seen any loss end your car is still running fine.
  14. Mendel Leisk
    41,898
    What kind of clamps? Hopefully not screw type. Are the original ones rusty?? I can’t seem them failing.
    One of those will be engine coolant, and the other inverter coolant. Would be good to get the repair manual procedures for both; consider a short term subscription to Toyota Tech Info?
