Pink stuff leaking from engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mdmikemd, May 22, 2009.
  1. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    Hi all, it's been a long time for me. Is Galaxee still around? I know her husband is a Toyota tech.
    I was filling the washer fluid and noticed on the inside of the hood, there was a thin straight line of pink stuff, it looks like Pepto Bismol. The way it looked, I figured some pink stuff must have gotten on one of the wheels connected to the serpentine belt or the belt itself. I looked and saw some pink foam like material near one of the wheels that the serpentine belt contacts. It almost looks like it was leaking out from where the wheel center contacts or enters whatever pump system it drives. I checked all the fluid levels, esp the pink stuff in the mid back of the engine and everything is fine.
    Any ideas? I'm going away for the weekend, so I won't be able to get it to the dealer until next week.
    Mike
  2. Submarine Dude
    Submarine Dude Junior Member
    73
    Glendale, AZ
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    Water pump.
  4. Patrick Wong
    18,200
    6,474
    Hi Mike,
    +2. You need to check the coolant level in the translucent tank behind the radiator. You also need to remove the black plastic cover over the radiator and remove the radiator cap. The fluid should be at the top of the radiator neck. Replenish the Toyota Super Long Life Coolant in both places as needed.
    If you find that the leak is substantial I do not suggest driving the car on a long trip especially if ambient temps are high. Good luck.
  5. kammssss
    kammssss Member
    287
    86
    SoCal
    Hey, I got the same problem, too. I will be changing it myself this weekend. Maybe I will find time to write this one up. I will let everyone know, if I find the time. Is it true it cost around $400 to replace at the stealership? I thought I read a thread about someone who went to the stealership. They must be from SoCal.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I think *most* of these engines have this symptom. My car's
    had the "thin pink line" its entire life, with a little bit of
    pink crust around the edge of the water pump pulley, and I've
    topped up by a small cupful of coolant maybe twice over the four+
    years I've had this. The water pump bearing seals simply weep
    a teeny tiny bit of fluid, that's all. It just looks like much
    more when it gets flung all over the place by the spinning pulley.
    If the line isn't actually *wet* with coolant after driving,
    I wouldn't worry about it. Wipe it down with a damp rag if you
    want to track how quickly it reappears.
    _H*
  7. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Take a look at the belt-driven pulley and see if it looks like this:
    Note the pink inside it. If it looks like this you need a new water pump.
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    OT:
    I found a puddle in the corner of my garage today, and it took me a while to figure out where it was coming from - I had a gallon of SLLC sitting on a benchtop and it spontaneously developed a crack at the bottom of the container. I lost over half a gallon on the ground before I realized where it was coming from and poured the remainder into another jug. $20 per gallon at the dealer. Doh!
  9. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    That's exactly what it looks like. But all the fluid levels are fine, so it makes me wonder if it was just a mild "weeping" of fluid. I'll have the dealer check it out, I got an extended warranty.
  10. nthach
    nthach New Member
    174
    It depends on how well the gasket/RTV is sealing the pump. The factory seal is superior to one done during replacement. But if the pump weeps from the weep holes, that means the bearing seals have failed and the bearing is about to go south.
    From the looks of the pic, the water pump looks like a decent job if you're mechanically inclined. A 14 or 17mm wrench or socket undoes the tensioner pulley bolt, and I would imagine the pump bolts could be a PITA to get to but nothing a good ratchet can handle.
  11. kammssss
    kammssss Member
    287
    86
    SoCal
    Hey everyone,
    I just replaced my water pump. Here are some pointers:
    1. No RTV is needed. The gasket is a thin metal sheet, and it can only go in one way.
    2. You will probably lose about 1 gallon of pink stuff if you remove it on a leveled surface. That's all I needed, and I have been monitoring my work for the last 2 weeks.
    3. It should take you about 2 hours or less if your mechanically inclined. Anyone looking for a mechanic. I am from SoCal. I wouldn't charge you $400 like the stealership...LOL.
