Pinstripe removal?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LDB, Dec 18, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    The original dealer put pinstripes on my car. They were not part of the deal with the selling dealer but that's how the car came. There are two, one black and one a weird sort of gold color that is not an attractive color at all. I'd like to be rid of that one and/or both. Where would I go to get them removed? Thanks.
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Probably all you need is a heat gun or hair dryer to soften the adhesive holding it on. Then peel off gently and slowly. Clean up any remaining adhesive residue with alcohol or goo gone, etc. Then wax the car.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    If they are just vinyl tape, you can easily peel them right off with a little bit of heat as suggested ^^^. It's DIY job.
    Dylan Doxey likes this.
  4. PR1U$
    PR1U$ Junior Member
    29
    Far Nor Cal
    If they are vinyl you can use an "eraser wheel". You can find the at most auto paint stores.
