PiP 1st gen to Prime battery conversion
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Catalinux, Mar 3, 2021.
  1. Catalinux
    Catalinux Junior Member
    43
    Romania
    2013 Prius Plug-in
    Hi all,
    I just searched for a thread for a conversion from the 2.2 kWh battery of the first PiP to 4.4 kWh from Prime.
    Will that be possible?
    I suppose that it is necessary a charger and some wiring, I don't know about the ECU's but still it would be interesting if someone made such a modification.
    49,492
    anything is possible, but not everything is worthwhile. the modifications would be so major, that it would have to be a labor of love.
    prime are so cheap these days, there isn't enough love in the world
    mrlebop likes this.
  3. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    Step 1.
    dimensions, could it fit?
    step 2
    specifications
    Voltage # of cells, BMS arrangements
    Step 3
    connectivity, what connectors are used throughout the battery system?
    occassionally you luck out like in a leaf where you can transfer new cells into an old battery
    other times not so much.
    You start, I’ll wait for your progress answering these problems with solutions
    49,492
    suspension upgrade, remove the bench seat, replac with two buckets :D
  5. Catalinux
    43
    Romania
    2013 Prius Plug-in
    I guess so, Rmay635703 :), maybe as a project, it would be interesting to see the outcome of this. But you are correct, it involves more that just "few" modifications indeed. I'll stick with the 2.2 battery for now. I was interested because i found such a battery quite cheap, but a lot of headache to modify. All i wanted was a few more miles on the electric side than the actual, after a full charge.
  6. Catalinux
    43
    Romania
    2013 Prius Plug-in
    Hahahahah, yes, my wife will be so thrilled ;)
  7. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    The Prime's battery is 8.78 kWh, not 4.4. I'm pretty sure the voltage is higher, too. I know it's much higher than a regular Prius.
    I've done no research, so this is off the top of my head, but I think you'd need:
    • A bigger charger since the Prime charges with more current than the PiP.
    • A bigger inverter for the same reason.
    • Bigger wires between the inverter & battery to handle the increased current.
    • New ECUs from a Prime to control the system.
    • Possibly stronger rear suspension due to the increased weight.
    mrlebop likes this.
  8. bisco
    49,492
    pip is 4.4 iirc. if that's correct, o/p has already accomplished his objective (y)
    mrlebop and jerrymildred like this.
  9. jerrymildred
    11,511
    14,113
    Tampa, FL
    I thought that that 2.2 sounded puny. Not much more than a regular Prius as I recall.
