PIP (basic) vs GenII screen resolution?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by elmofongo, Apr 14, 2012.
  1. elmofongo
    elmofongo Member
    253
    SF, CA
    Any numbers out there?
    Did they just shrink the screen size and keep the resolution the same from my 2006 No-Nav model?
    49,437
    i don't have any numbers but i think the screen quality is excellent compared to my 08.
  3. mikenewmediary
    100
    24
    Bridgewater, Ma.
    Bisco,
    you have a base or advanced ?
    Your profile does not indicate either...
    Mike
    49,437
    base. i'll take a look at that, thanks! edit: that's better, thanks mike!
  5. mikenewmediary
    100
    24
    Bridgewater, Ma.
    This morning I drove my daughter to her softball game. It was very bright sunny morning. I could not see the nav screen.
    This happen to anyone else, and if so what have you done to correct?
    Mike
  6. mikenewmediary
    100
    24
    Bridgewater, Ma.
    If figured this out.
    My friend drove the car last night, his knee must of hit the dimming switch. If you put it to MAX, it actually clicks, and is at the brightest
    setting.
  7. bisco
    49,437
    i hate when that happens! :D there is also a day/night setting in the mfd controls, is there not?
  8. Priuskat
    Priuskat Junior Member
    36
    Orange County, CA
    There is also a contrast setting in the navigation that helped the glare . .
  9. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    That behavior tells me that you had the headlights on. The dimming switch has no effect on dash brightness when the headlights are off.
  10. longterm
    longterm Member
    152
    Nashville, TN
    Where's that setting? I couldn't find it on my base model.
