PIP battery code, help?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tariq777, Feb 1, 2020.
  1. Tariq777
    Tariq777 Junior Member
    Jordan
    Hello everybody,
    Can anybody help know the following PIP battery manufacture date?
    Thanks for the help in advance.
    Regards
    49,443
    i don't see anything?
    Tariq777 likes this.
  3. Mendel Leisk
    38,709
    Yeah if you're trying to post a picture, it may be necessary to post a few more times (4 or 5?), before the software will allow it.
  4. Tariq777
    Jordan
    Hello guys
    Thank you for responding
    The code is exactly as follows on one of the tags:
    23A011
    4701013
    B010040
    1.1kw
  5. Tariq777
    Jordan
    This code is on top of the whole battery
    23JTH24713113B270037
  6. bisco
    49,443
    If there’s a date code in there, idk how to translate it, sorry!
  7. QuantumFireball
    QuantumFireball Active Member
    419
    269
    Ireland
    I can't find any information about date codes on the traction batteries, unfortunately.
    Do you have any reason to believe it's not the original battery? Do you know the age of the car?
  8. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Perhaps the module serial numbers follow the sequence posted here for other Prius modules.
  9. Tariq777
    Jordan
    Hello,
    Thanks for taking the time to reply.
    The car is pip class g 2014
  10. Tariq777
    Jordan
    Hello,
    Thanks for the suggestion but unfortunately I tried but it doesn't apply.
