PiP battery heath check
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Iain Millar, Apr 28, 2021.
  1. Iain Millar
    Iain Millar New Member
    UK
    I'm looking at a second hand 2013 PiP, how can I check the traction battery health? Does the Dr Prius app work with the 4.4kwh Li-Ion battery?
    Anything else I should particularly look for? Cheers!
    49,401
    welcome!
    the best test is plug it in until fully charged, and then take it for a spin on back roads around 30mph.
    you should get 10-13 miles before the engine comes on.
    make sure you're not calling for heat or defrost, that will start the engine.
    idk if doc prius will work, but i doubt it.
    how many miles on her?
  3. Iain Millar
    UK
    Thanks for the reply! She is a 2013, with 95k miles.
    Did very regular 13k miles a year till march 2020 Then just 2000 since, so she has been sat for some months.
    I've asked the dealer to charge it fully for a test drive tomorrow, will check the EV range as you've suggested.
    I have found Toyota UK do a HV battery check for £45 which I might see if I can get done. (It seems that test looks at: Internal Resistance; Internal Voltage; Variation Check; Battery Temperature; Fuel Consumption; Battery cooling system)
    I found she had a 12v battery voltage of 11.7V initially.
    And the washer fluid dipstick was dry and gunky.
    Are these likely to cause issues? I can negotiate to replace the washer pump and 12v battery if long term damage is likely from being sat for months.
    Cheers!
