PiP 'burns' EV range in HV mode (not regen)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Dec 22, 2013.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,550
    720
    With a full charge from the wall and the ICE warmed up, the PiP will still eat through about 4 miles of EV range while in HV mode. I can't figure out why it does this.
    At first I thought maybe the ICE wasn't really warmed up so I conducted an experiment. I unplugged the PiP after a full charge and started it in HV mode. The ICE kicked on and I let it idle until it turned itself off. Then I started driving in HV mode. The PiP still chewed through 4 miles of EV range while driving in HV mode even though there was no hard acceleration.
    Has anyone else seen this?
    Michael999 likes this.
    49,387
    yes, but everyone seems to have different experiences. my first 4 miles of driving are very ev friendly and it's difficult to even get the ice to come on. in the summer, when i start with range of 16, i'm down to about 12 when i hit the highway, all hv mode. some say the ice then recharges the battery, but mine does not.
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I think it is normal. Mine uses some of the EV range indicated while driving in HV mode, and replaces it off the running of the ICE. I have observed this when driving with no braking needed. However, just like the OP's, it tends to stay at about 3-4 miles below the full charge level I had when I started the trip, unless I get some downhill or brake regen going. I'm not an engineer, nor do I play one on tv, so I'll leave the technical explanations to the guys on here who really understand how the systems work.:p For me, it comes down to the fact that the car seems to have the ability to figure out what works best for the driving conditions, so I don't have to worry about it.:D
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Yup, normal. Full charge SOC is 85% so it will try to go down to more comfortable 75-80%.
    Thats when full power regen is allowed as well.
    CaliforniaBear and markabele like this.
  5. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Prius PHV is a plug-in hybrid. That means it will use the electricity in the most efficient way possible. So... you'll see EV consumption while in HV mode. It's a fundamental part of the design to achieve high MPG and clean emissions.
    You'll also see the EV capacity reduced to a lower level for longevity. In other words, the "full" level of 85% is not the ideal for maximum battery life. It's in the low 70's. So, no matter how much you try to sustain a capacity above that while driving, it will consume electricity to stay at that happy place.
    Kudos to you for being so observant and asking questions. The system is well thought out and there are many variables at play. Of course, when we provide more information, it tends to open a can of worms. But understanding what goes on and why certain approach decisions were made has to start somewhere.
    What I find most interesting is how rapid the transition from engine to motor is when the system is warmed up. You can take full advantage of gas to accelerate and immediate switch to electricity the moment you let up on the pedal. Antagonists spin that as a shortcoming. But with a such an efficient power-split design and a small battery capacity, forcing the system to rely entirely on electricity doesn't make sense.
  6. PiPLosAngeles
    1,550
    720
    Unless the Toyota engineers specifically programmed the PiP according to the route I'm going to drive each morning and the weight of the cargo and passengers I'll be carrying, there's no way for it be pre-programmed to use electricity in the "most efficient way possible." The best we can hope for is a good guess based on average conditions.
    When I get in my PiP in the morning I know exactly where I'm going, what speed, the topography, and what kind of load I'm carrying. I guarantee that if I'm not being overridden by the car I can achieve better efficiency than can be achieved just "leaving it alone." Lots of people do not want to bother with being hypermilers, and that's OK. A good product, whether a car or anything else, allows it to "just work" for those who don't want to fuss with things and allows for manual overrides to those who want to push the envelope. What bugs me is that the PiP has controls for manual override, but it commonly ignores my input to those controls and it's doing so in a way that hurts efficiency. Heck, it even does this with the climate controls which still make me nuts changing from recirculate to outside air when I turn off AUTO, or vice versa depending on the phase of the Moon or whatever logic is in there.
    The situation that motivated my post is that sometimes my route from home is directly up a 7% grade for several miles, and then level to slightly downhill for 15 miles. The most efficient strategy in that case is to use the ICE uphill and EV for the rest of the trip, but the PiP is overriding my inputs to prevent me from executing the most efficient strategy.
    Keeping the battery at 85% for an additional three miles where there will be no regen isn't going to hurt longevity in the slightest. Again, Toyota doesn't know that is the character of my route, but I do and the PiP is preventing me from "telling" it.
  7. CharlesH
    2,785
    1,152
    Roseville, CA
    Part of the issue of the ICE running at "random" times are emissions standards that Toyota needs to comply with. This is reason that the original Volt did not qualify for the HOV decals in California: the entire battery + ICE system has to be considered, and the ICE in the Volt did not meet emissions standards to qualify for the HOV decals. The temperature of the ICE effects how well things like the catalytic converter works. So the control system for the PiP has to take into account minimizing emissions along with things like mpg efficiency. Note that mpg is not necessarily related to emissions; an SUV can burn gas at a voracious rate, and then have an aggressive emissions system scrub out the "nasty" stuff, and end up with low emissions (and low mpg).
  8. markabele
    5,084
    1,782
    Nebraska
    You really think they design cars for the most intelligent users? Heck no, they idiot proof them.
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! I'm safe!!!
    No problems here. :whistle:
  10. 3PriusMike
    2,963
    2,314
    Silicon Valley
    I don't think making broad statements like this is in the best interests of all those reading. It makes it seem like the car is perfect and don't question or mess with anything it does. The PIP is taking into account enery efficiency. low emissions, car longevity, battery longevity, engineering limits etc all at once in the choices it makes. This is quite different than what a conventional car does -- you push the gas pedal and it makes the engine go.
    Mike
  11. PiPLosAngeles
    1,550
    720
    Are we certain of the reason the PiP insists on driving in EV-assist mode while set to HV mode until three or four miles of range have burned off, or is it just a theory?
    Burning off SOC doesn't make a lot of sense. If I plug the PiP in Friday evening when I get home from work it charges all the way up to the reported 85% SOC. Many weekends I'll never drive the car, so it will sit there for 60 hours with the battery at 85% SOC. There's no mechanism in the PiP to shed that charge in the event that the car isn't using it immediately. On the other hand, if I get into the PiP three hours later and start driving, now it's suddenly so urgent to shed that charge that we need to override the driver's manual control? We could speculate that Toyota engineers were worried about regen taking the SOC over 85%, but the PiP already has a mechanism to prevent that where the the ICE is run to bleed off excess regen. I find it hard to believe that 85% SOC is enough of a concern that the PiP is programmed to override HV mode and operate in EV-assist while at the same time it's of no concern to have it sit parked indefinitely with the same 85% SOC.
  12. bisco
    49,387
    theory. everything discussed here is theory.;)
    Lourun and retired4999 like this.
  13. markabele
    5,084
    1,782
    Nebraska
    I think it recommends in the manual to charge it right before you use it (ie. don't let it sit there forever with full charge). Having the timer in the car is pretty much the same as Toyota saying....hey it's best to not let it sit forever at full charge. Otherwise they wouldn't have it there and just have people plug in right away.
  14. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    As Mark mentioned already, the manual said to avoid it. The SOC for long term storage is at around 20% (HV mode with no EV miles).
  15. rorystewart
    rorystewart Junior Member
    48
    2014 Prius Plug-in
    I have a related question that I’m hoping someone can answer/explain:
    I was flipping through the owner’s manual and it said to use the charging timer to prevent long term degradation or damage to the battery. But this is confusing to me because the prius stops charging itself once it’s fully charged. I know because chargepoint tells me when the car stops drawing power. I also know because if I leave the car plugged in overnight into a 110v outlet the little charging light is off in the morning and the screen tells me the car is fully charged and stopped drawing power.
    So my question is why do we need to use the charging timer to prevent battery degradation? It the manual wrong? Can’t the car just stop charging itself when it’s full? Why do I need to set a timer to tell it when it should be full and stop charging?
    Is the point maybe to have it only charge for 2 hours from a 110v outlet instead of three so it only charges to about 60-70% SOC instead of 85%?
    Thanks in advance!
  16. markabele
    5,084
    1,782
    Nebraska
    The point is to have it sit the least amount possible at a "full charge." Sitting at the full charge long term is not good on the battery. So ideally you would use the timer so it shuts off right before you leave.
  17. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    Think of battery as your bladder. You don't want it near full for a long period of time, if you want to keep it healthy for as long as you can. You also don't want it too empty as well.
    You can temporarily go there for the sake of more EV miles. The manual is just saying don't abuse it.
    It is range vs life. The best compromise is achieved using the timer to get the best of both. No matter how you use it, the same battery warrenty applies so, perhaps the timer is to extend the life beyond 10 years / 150k miles.
  18. bisco
    49,387
    you only need to use the timer if you are not going to use it reasonably soon after it finishes. i have never used it because i can charge and go. but if you go at seven in the morning, do you want to get up at four plug in? so you set the timer the night before to come on at 4am, so it doesn't charge up and sit full all night.
  19. rorystewart
    48
    2014 Prius Plug-in
    Makes sense. Thanks.
  20. PiPLosAngeles
    1,550
    720
    That's a strange interpretation. My thought was that the timer was there so we could charge during off-peak hours without having to get out of bed to plug it in at the right time.
    "Long term storage" in terms of lithium batteries is measured in months and years, not hours. It's a two-way street too - long term storage at too low of a SOC will also damage the battery if the self-discharge takes the cells below 2.0V.
