PiP Fuel Efficiency: Cost per Mile
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JimPHL, Dec 7, 2012.
  1. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    Hello everyone. I've been reading your postings and appreciate your insight and especially your humor!
    My daughter picked up a PiP in August. I had visitation privledges on Sundays; to wash it and fill it up! I instantly fell for this vehicle, researched like crazy, read a gazillion PriusChat posts, and took the plunge in mid September.
    I have never been so engaged wiith a vehicle. The technology is mind-blowing and am loving every mile, especially the feedback from the vehicle that allows me to be more fuel efficient.
    I've noodled on how to measure the fuel efficiency so I can see how my driving improves efficiency and to compare the PiP to other vehicles, espeically our Highlander and Venza. The flexibility of fuels that the PiP uses maks this a bit of a mind bender. I've concluded that the common denominator that ties this all together is Cost per Mile. I've pulled together the attachment to try to convey my perspective. So, in the best PriusChat spirit, please pick it apart and share your perspective.
    P.S. I had to convert my Excel spreadsheet to a pdf file to post it. Can we upload Excel spreadsheets?
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    A few of us track our numbers in this spreadsheet (its also stickied at the top of the forum)
    PiP Owners Spreadsheet
    At about $0.05 per mile, you're doing pretty good. Looking over our spreadsheet, the numbers seem to range around $0.02 to 0.07, with a majority around the $0.05 to 0.07 range it seems (this is based on a fixed $0.12/kWh and $4.19/gallon of gas for comparison purposes).
    And welcome to Priuschat!
    lensovet likes this.
    51,154
    welcome to p/c! i think it is a very good way to do it. cost depends on how much you drive ev and how much ice. how much are you paying per kwh?
  4. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    Tracksyde, Thanks for the feedback. I will check out the spreadsheet over the weekend.
    bisco, My electric runs about $0.18 per kWH, which is $0.12 for the electric and $0.06 for distribution. I have PSE&G in southern NJ.
    Follow up question...any suggestions on how to isolate the variables that drive fuel consumption, or am I over-thinking this? The electric vs. gas usage, best situations to use each, hypermiling techniques, etc, are rather overwhelming as they all come into play simultaneously!
  5. John H
    John H Senior Member
    2,208
    558
    When calculating your electrical costs you might need to adjust the kWh reported in the PiP to compensate for charging losses. The PiP spreadsheet uses 15%, or you could just add 3 cents to your kWh cost.
  6. JimPHL
    JimPHL Member
    74
    33
    Cinnaminson, NJ
    Tracksyde, nice workbook. I have some data to collect/back into before I update. I will add my first two fill ups and keep this up as I move forward.
    John, thanks for the input on the spreadsheet. I've added $0.03/wWh and recalculated.
    The numbers & driving expereience convince me that I made the right decision with a PHEV:
    * Super-efficient vehicle, with a cost per mile that is one-third of my other vehicles
    * Electric car experience with many of its benefits but not the range anxiety
    * Engaging driving experience with timely feedback as I change my driving techniques
    I've attached the updated file. Thanks all for your feedback. Jim
  7. John H
    2,208
    558
  8. Much More Better
    Much More Better Active Member
    655
    163
    Welcome to PC! The electric cost per mile seems almost the same as gas cost per mile (less than 1/2 a penny). I imagined running on electricity to be much cheaper than gas, in order to make some financial sense. I wonder what other owners in your climate are getting in the regular Prius? That said, you are enjoying the heck out of it so not everything boils down numbers and payback. There has been many threads trying to figure out payback for a regular hybrid and it never works out in favour of the hybrid, unless you compare it to SUV and trucks.
    My local rates are $0.08 per kWh and even at those rates, it takes FOREVER to make up the price premium for the plug-in. But most of my drives are short and I enjoy the electric feel so I'm willing to pay for it.
  9. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    I've got this comparison of my savings, based on my 11 partial and full fillups since April 2012.
    Total Gas Gal: 85.720 Add Gal
    Total Gas $: $ 322.54 Add $
    Total kWh: 1090.00 Add kWh
    Total Miles: 7852.1 Add Miles
    $ per Gal: $ 3.76 Divide Total Gas $ by Total Gas Gal
    kWh $: $ 95.92 Multiple Total kWh x 8.8 cents per kWh
    kWh Gal: 25.492 Divide kWh $ by $ per Gal.
    Equivalent Gal: 111.212 Add Total Gas Gal + kWh Gal
    MPGe: 70.60 Divide Total Miles by Equivalent Gal
    If Typical MPG: 50.000 2012 Prius Standard MPG
    Typical Gal: 157.042 Divide Total Miles by Typical MPG
    Typical $: $ 590.90 Multiply Typical Gal x $ per Gal
    Total $: $ 418.46 Add Gas $ + kWh $
    Savings $: $ 172.44 Subtract Typical $ - Total $
    If Typical MPG: 35.000 2007 Prius Standard MPG
    Typical Gal: 224.346 Divide Total Miles by Typical MPG
    Typical $: $ 844.15 Multiply Typical Gal x $ per Gal
    Savings $: $ 425.69 Subtract Typical $ - Total $
    Tracksyde likes this.
  10. Much More Better
    655
    163
    ukr2: According to your calculations, you save $172 over a standard Prius. If extrapolated over a full year, you save $229. (172/0.75)
    If a base PiP is $32000 and a Prius Four starts at $28500, it would take over 15 years to payback plugin premium. ($3500/229) Although I didn't compare spec of each, I'm gonna guess the P4 is much better equipped. Comparing a PiP Advanced to a P4 is even more ridiculous. Not factoring in local rebates, it's gonna take the intangibles of plug-ins in order for it to sell. (lower emissions, silence, lower carbon footprint, being first on the block, etc).
    I'm hoping the next-gen will give greater EV range and lower MSRP (within reason). By relying on more electricity, the math will hopefully make PiP owning a little more sensible.
    edit: payback of PiP advanced over a Prius 4 at $229 savings/year is 48 years.
  11. John H
    2,208
    558
    I calculate 66.5 MPGe combined.
    7852 / ( 85.72 + ( 1090/33.7) )
    I didn't take your kWh --> Gallons through a $ equivalent.
  12. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    John,
    Where do you get 33.7 Gal/kWh from?
    I just determine the kWh cost with my 8.8 cents/kWh, and divide it by Gas $/Gal to get equivalent Gas Gallons.
    John Hatchett likes this.
  13. lensovet
    2,615
    496
    Burlington, NJ
    The appropriate comparison to make for the base model is to a Prius three due to the cloth seats. However plugin adds heated seats and remote A/C which are not in the three, so add 1k for that.
    CA residents basically get $4k back
    End-of-year incentives due to 0% APR and additional cash back from TFS made the base plugin cheaper than a three after all rebates and incentives.
    Appropriate comparison for the advanced model is to a Prius five, not a four.
  14. John H
    2,208
    558
    Miles per gallon gasoline equivalent - Wikipedia, the free encyclopedia
    It would be 33.7 kWh = 1 Gallon.
    Note, I also assumed your kWh is measured at the wall rather than at the battery.
    @ $0.088/kWh your gallon gas equivalent should be $2.9656, but since the PiP is about 95MPGe on electric you save money the more you drive EV !!
  15. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    I did get $2500 off my taxable income too.
    AND I'm not paying for 1/2 my kWh. The office isn't charging me.
    Plus I enjoy only getting gas once a month. (I had a few partial fillups because I reset my Fillup Trip by mistake !!!)
    If I was focused on Payback, I would buy a Scooter.
    I owned the 2007 Prius and liked it. I LOVE the PIP.
  16. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Also, what's the Payback in drinking that Beer verses a Glass of Water???
  17. Much More Better
    655
    163
    i knew your decision wasn't based on economics. I didn't buy my prius based on payback either. Your numbers got me thinking about math, that's all
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    95 MPGe is with 0.2 gallon of gas and 29kWh/100mi combined. If you drive in the city so that ICE doesn't trigger, it can be as high as 117 MPGe (29kWh/100mi).
    He is getting between 25.6 and 29.4 kWh/100mi so that's 116 to 132 MPGe on electricity. His gas efficiency is 57.4 to 63.2 MPG.
    PiP is very efficient with either fuel.
  19. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Here are some simple ways to calculate costs:
    One full charge (for me) is always less than 3 kw-hr (usually 2.85 - 2.95 kw-hr measured by Chargepoint or watt meter). This includes all possible charging losses between the wall and the battery My estimated miles per charge is about 14, but has been down to 13.5 and as high as 15. My actual miles drivien is usually about 0.5 to 1 mile more than the reported number. This is for 30-45 mph city driving. When I'm at 60-65 on the freeway it is more like 10 miles. For most people (without heat, A/C, etc) you will get from 10-15 miles per full charge on level ground.
    Therefore: (3 kw-hr) / 10 or 15 miles = 200 to 300 w-hr per mile; or 2 cents to 3 cents per mile given a cost of $0.10/kw-hr.
    If I compare this to a long term average from the PIP's display...I see about 349 kw-hr for 1876 miles. This calculates out as only 186 w-hr/mile, but does not include any charging losses. The PIP, reportedly takes 2.7 kw-hrs per charge "into" the battery. If it consumes 2.85 - 2.95 at the wall, this is a loss of about .15 to .25 kw-hr or around 5% - 9%. This is lower than the 15% number I keep seeing referenced. I don't know where the 15% number comes from, but I do not think it was measured, but maybe comes from Toyota or some place else. This number is most likely the combination of both charging and discharging losses. I do not think it makes sense to double count the discharge losses, because we can't distinguish these from just driving, friction, motor efficiency, etc.
    Given the same driving conditions (except maybe use of heater/defroster) with gas it will be 45 - 55 mpg and gas cost $3-$4/gal. At 50 mpg this is: ($3/gal) / (50 miles/gal) = $0.06 per mile. $0.08 for $4 gas.
    You have to be paying $0.30 - $0.40 per kw-hr to be losing with electricity overall.
    But wait, there's more....
    Since many times you are driving short distances to the store, restaurants, school etc, these short trips at low speed tend to be at the lowest watt-hrs per mile, thus lowest end of the costs per mile. But if you where to drive these with gas you would typically not get the car warmed up yet...these trips would have usually been at maybe 25 mpg for the first 5 minutes. The comparison here is like 1.5 - 2.0 cents per mile (electric @ 10c/kwh) to 12 - 16 cents per mile (gas $3 - $4); a clear win for electric even at 50c/kwh.
    Mike
  20. John H
    2,208
    558
    I believe the consensus is 15% at 110V and 10% at 240V but there are definitely variations based on ambient temperature and state of charge.
