PIP U-turn noise from front wheels
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kenp11, Feb 5, 2014.
  1. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    Anyone get a noise in their front wheels when doing U-Turns or sharp turns(Maybe too fast)
    It almost sounds like brake rotor pulse noise. Is this regen brake issue or problem?
    49,437
    could it be tyre/road noise?
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I have also experienced this, and I got worried so I attached tech stream and recorded the car, it's abs and traction control kicking in, there is nothing wrong to be worried about :). I would recommend slowing down if you don't want to hear it
  4. kenp11
    74
    Orange
    2014 Prius Plug-in
    It usually happens when i turn from a higher driveway. I think i am getting to the angle of the wheel/steering to when it does it.
  5. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    It's only happened to me when I did a u turn at around 15mph or so I can't remember. Btw you are posting in the plugin sectio of the forum, I would recommend the problems not specific to plugin be posted in the appropriate section.
  6. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I get a bit of clunking sort of sound myself, when turning the steering wheel at slow speeds such as in parking lots. Maybe it's normal for the Prius?
  7. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Do you hear any beeps or do any lights flash on the mfd or speedometer
  8. mediahound
    903
    155
    No.
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Could it be your tires screeching?
  10. mediahound
    903
    155
    What would the screech from? It sounds more like a clunking.
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Does it pulse?
  12. mediahound
    903
    155
    I think it's only when I'm turning the steering wheel. Might just be the steering wheel pump or something.
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    These cars don't have a steering wheel pump they have electronic power steering
  14. bisco
    49,437
    i don't think clunking is normal, if it's reproduceable, i would take it to the dealer.
  15. kenp11
    74
    Orange
    2014 Prius Plug-in
    For me it pulses like ABS when it is hit hard
  16. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    then there's nothing to worry about
