Pip Weight?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by nickfromny, Jan 26, 2016.
  1. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    How much more does the PIP weigh vs Std Gen 3?
  2. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Plug-in Prius curb weight 1420 kg.
    3rd gen Prius curb weight 1379 kg.
    Note that the Plug-in Prius has no spare tire.
  3. markabele
    5,084
    1,782
    Nebraska
    That equates to about a 3% difference.
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    I assume that the Advanced weighs more than the Base, due to the additional gadgets?
  5. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Well, in Canada the weight range is 1435 - 1460 kg for the PiP. That's higher than the 1420 kg I posted earlier BTW.
    For the regular 3rd gen Prius, the weight range is 1380 - 1397 kg in Canada.
    That means the difference in weight ranges from 38 kg (lightest PiP - heaviest Prius) to 80 kg (heaviest PiP - lightest Prius) depending upon the model, with the difference in weight between the heaviest models being 63 kg (heaviest PiP - heaviest Prius). That equals 139 lbs.
    Judging by those Canadian numbers, the extra gadgets in the Advanced/Technology package weigh 25 kg (55 lb).
    #5 Eug, Jan 26, 2016
  6. nickfromny
    309
    24
    Binghamton, NY
    Figured the extra Batteries would weight at least 100lbs But its good to know
    My Gen 2's had a tendency to snap oversteer when fully loaded.
    They required more air pressure in the fronts to counter the heavier rear end and induce under steer.
    Usually 2-4 lbs more of air pressure in fronts.
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Way back, when I had a Prius PHV demo car for a while, I drove it up on a set of scales and weighed it. The result: Mark gets a shot at driving the PHV Prius in and around NYC | Page 2 | PriusChat
    Granted, this was a pre-production demo car but it brought back a memory so...
