Placement of EZPass
Discussion in 'Prime Main Forum (2017-2022)' started by Oskar, Sep 27, 2020.
  1. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Just picked up a Prius Prime Limited, loaded, and has all sorts of sensors and doodads attached. I want to place my EZPass transponder on the front window just under rear-view mirror, but am not sure if it will interfere with the cars sensors, or vice versa. Any thoughts on this? I suspect it won't have any affect, but want to be sure. Thanks.
  2. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    Avoid the silk screened black areas you’ll be fine.
  3. Trollbait
    11,560
    That's where I put it in the Camry, and haven't had a problem.
    Are those ares considered too close to the forwards sensors?
    Raytheeagle likes this.
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I just rest mine on top of the dash as needed (which is not often), no fixed attachment.
  5. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    I have mine attached right on the black plastic casing of the front camera right behind the rearview mirror. It is totally out of site from outside or from inside unless looking from the side behind the rearview mirror as shown in the photo below. Never had a problem either with car sensors or with the tolls.
    #5 Salamander_King, Sep 27, 2020
    Dael and pghyndman like this.
  6. schja01
    1,746
    1,162
    Chicagoland
    2018 Prius
    I got an EZ/SpeedPass holder with suctions cups. Nice for trips and doesn’t gums up the windows with those Velcro strip’s adhesive. When the trip is over it’s back in the glove compartment again. Early on I just laid it on the dash but it slid around too much.
  7. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    Works perfectly inside the top glove compartment in Gen2.
  8. yaun
    yaun Member
    71
    64
    MA
    Same here, mounted in the black dot area and no problems with it at all. The black dots enamel doesn't interfere with RFID signals.
  9. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Many thanks for the quick replies. Most appreciated!!
  10. Dael
    Dael Member
    128
    32
    Ohio
    2020 Prius Prime
    from Ohio EZ Pass site, "*Certain vehicles do require special mounting. Some newer vehicles may have devices that can throw off the signal of the E-ZPass. Make sure the E-ZPass is not mounted near these devices (remote start, GPS, Satellite Radio, rain sensors or anything else that is metal or mechanical). The best location is typically in a lower corner close to the dashboard and still on the windshield."
  11. schja01
    1,746
    1,162
    Chicagoland
    2018 Prius
    I mount mine on the windscreen behind the rear view mirror where I can’t see it and not on the black silkscreened area.
    Dael likes this.
