Placing (shifting) into Reverse
Discussion in 'Gen 3 Prius Main Forum' started by dmdmark, May 15, 2011.
  1. dmdmark
    dmdmark New Member
    Washington
    After I start the engine, place my foot on the brake and then move stick into reverse, the car "jerks" back. This happens 25% of the time. This never has happened going into drive mode. Any thoughts ?
  2. macmaster05
    macmaster05 Senor Member
    4,050
    727
    Don't you need to put your foot on the brake before you power on the car? Anyways, it sounds like you're not using the emergency (left foot) brake - as in it was never engaged. My routine:
    Step on brake hard
    Hit Power
    Release E brake
    Shift to R
    48,862
    probably depends on whether the engine is running or not. it comes on more in reverse than forward.
  4. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    First, whether the engine is running or not, the car will not notice in "R" as -all- motive power comes from MG2. The engine just spins.
    Second, do note that the Prius will jerk a bit when it's cold (before you warm up the transmission oil). This may be what you are seeing.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    When the engine is running it produces forward torque on the drive train. This is opposed and overpowered by MG2 in reverse, so the car will back up, but MG2 is working against the ICE in this configuration. In this respect it does make a difference whether the ICE is running or not.
    ICE startup produces a jump in torque which can sometimes produce a jerk. This is true going forward or backward, but is most noticeable at slow speeds.
    Tom
    HeadOfJarg likes this.
  6. dmdmark
    dmdmark New Member
    Washington
    Thanks for your reply. I actually do your suggested routine, but I still occasionally get a loud "snap" sound when putting the stick into R and sometimes even N. Never get it in D.
  7. dmdmark
    dmdmark New Member
    Washington
    Sorry for my lack of knowledge, but what is ICE? Why would I hear this loud "snap" sound only placing in R, not D?
  8. barcelona11
    barcelona11 New Member
    71
    Central NC, USA
    ICE = Internal Combustion Engine (ie, the gas engine). Sorry, I have no clue about your second question.
  9. qbee42
    18,058
    3,073
    Northern Michigan
    Sometimes you hear a snap as the electrical relays close. It's an arcing sound, like something from an old Frankenstein movie. As for why you hear it only in reverse, that is probably a function of the specific relay.
    You can also get a different sort of snap sound when the car starts to roll if the brake pads have stuck to the rotors.
    Tom
  10. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    The snap might be the solenoid actuated parking caul or pin releasing. It's located between the ICE and the HSD. Part of the coil spring torque load damper clutch assembly that connects the two.
  11. Old Bald Guy
    Old Bald Guy Old Bald Guy
    89
    Ft. Worth, TX
    Just a note here, you will never feel a jerk from cold transmission oil ... the Prius doesn't have a transmission ... or a clutch ... or a torque converter. Both electric motors and the ICE are connected full time to a single planetary gearset which, in turn is connected through a single reduction gear to the differential.
    The so-called "cvt transmission" is merely the computer controlling the speed of the ICE and the speed and direction of the 2 electric motors. For a graphic of how the planetary works, go here Toyota Prius - Power Split Device
    HeadOfJarg, wesayso and qbee42 like this.
  12. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Is it possible that the OP is parked on a incline. The sound that he's hearing is normal, parking paw disengaging from locking ring. ???
  13. David Beale
    5,963
    1,979
    Edmonton Alberta
    Correction. There are no gears shifting, but the Prius DOES have a "transmission". Power is transmitted to the wheels via the transmission and there -are- gears in there, planetary and others. There is also a chain. And when cold there is more drag so you can feel it when the drive changes. Usually only when you "shift" to "N" or "R". Even with your foot firmly on the brake (so there is no drive from fake "transmission creep").
  14. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    This is the best guess i have seen. My car never does what the OP was saying. If i start my car and after i back up about ten feet the ICE then starts up producing noise but does nothing to make me jerk backwards, but it does make a snapping noise.
  15. qbee42
    18,058
    3,073
    Northern Michigan
    Most people use the term "transmission" to mean a shiftable transmission, but any device that "transmits" power from one location to another is a transmission.
    Tom
  16. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    cool graphic
  17. Kasra
    Kasra Member
    48
    26
    Irvine, CA
    I have the same symptoms as the OP. this has nothing to do with engine hot or cold, sometimes it happens after my drive home. As soon as I shift in Reverse, there is that kick. It's almost like when you shift into R as the car is still rolling forward (But it actually isn't).
    I also have waited 5-10 seconds before shiftinfrom D to R, but still there.
  18. Mendel Leisk
    38,108
    What’s the miles on it? Have you had it since new? (Wondering if someone might have used an alternate fluid in it.)
    Easy first step, if it’s not been done: change transaxle fluid. May or may not help, but good to do at least once.
