plastic bug shield for 06 pruis
Discussion in 'Gen 2 Prius Main Forum' started by seaside man, Aug 28, 2006.
  1. seaside man
    seaside man New Member
    Does anybody know the web site where i can buy a bug shield like on that canadian yellow taxi..it looks real nice or if anybody know other web sites to purchase this item please let me know i have 2000 miles on mine and no chips yet need to get something on it soon ...thanks
  2. onerpm
    onerpm New Member
    477
    MN
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(onerpm @ Aug 28 2006, 09:21 AM) [snapback]310571[/snapback]</div>
    How does it effect you MPG. My guess is the answer is not good?
  4. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(hdrygas @ Aug 28 2006, 12:42 PM) [snapback]310583[/snapback]</div>
    I have one on my '06, and I think the impact would be negligible, at least not enough to notice a difference.
    One thing to keep in mind that I learned after having it installed (Toyota OEM) is that it sits flat and very close to the hood (1/4"?) so there is minimal disruption of air flow. Unfortunately, this also means it is very difficult to clean underneath it, so I will need to remove it in order to do a proper cleaning (haven't tried this yet). It is in fact mounted with little screw clamps, not taped.
    I am averaging 50MPG through my first 4 months of ownership, mixed city/highway, but generally getting better with each passing tank. ;) I think a couple of low-to-mid-40's MPG tanks of Toronto-Montreal freeway trips at 72MPH is pulling my average down a bit. <_<
    Kevin
  5. onerpm
    onerpm New Member
    477
    MN
    I couldn't see any difference in MPG.
    Haven't seen any need to clean under there, either. If I'm self-washing the car, I might squirt the hose under there.
    rpm
  6. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    If you go to the toyotapartsstore.com site and select the 2005 prius you will find a hood protector on sale for $50.01 plus shipping. It also fits the 2006 and has the oval cutout where the hood emblem is. You can email them and ask about it. I bought mine at Auto Seattle and paid a lot more for the same thing.
  7. seaside man
    <div class='quotetop'>QUOTE(FL Buckeye @ Aug 28 2006, 04:57 PM) [snapback]310756[/snapback]</div>
    Hey buckeye do you really like your bug shield?I'm thinking about getting one on my 06 model ...does it have little bumper guards underneith so it doesn't touch the hood at all?And is there a cut out for the toyota emblem.
    Thanks for any info and if you have a pic of it please send...thanks again...jeff
    Hey buckeye do you really like your bug shield?I'm thinking about getting one on my 06 model ...does it have little bumper guards underneith so it doesn't touch the hood at all.
  8. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I like the bug shield idea, but does anyone know if the black bra is being made to fit the 2006 yet????
  9. Jennjay
    Jennjay Member
    142
    Fort Myers, FL
    How does the bug shield go on? Is it an adhesive that may mar the paint, drilled or secured in some other fashion? Thanks
  10. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    <div class='quotetop'>QUOTE(seasideman @ Aug 28 2006, 07:29 PM) [snapback]310798[/snapback]</div>
    It has 3 little "bumpons" that adhere to the hood tp prevent the shield from ever touching it. I think I already mentioned that there was a cutout for the emblem. I really wanted a shield that stuck out from the hood to be able to clean/wax the hood under the shield without removing it, but couldn't find any. This one sets real close to the hood, maybe 3/8 to 1/2 inch away. I don't notice any wind noise from it or rattles. There are 6 clips that attach the shield and they go over plastic film pads that adhere to the edges of the hood. There used to be some pics of hood protectors on threads here but the hacking of the site the other day must have deleted them. I'll try to take a couple this week. I could email you the instruction page if you want. On the instructions the shield is called a Form Fit hood protector bu the sales receipt says its a Benevento BVBG-0179. I found the one on toyotapartsstore after I already bought mine. I emailed them to ask about it and it sounded like the same shield as I have. If I find one that mounts further away from the hood I will get it but until then this one works fine.
    <div class='quotetop'>QUOTE(Rangerdavid @ Aug 28 2006, 07:37 PM) [snapback]310805[/snapback]</div>
    I can't answer your question about any improvements to fit the '06 but I have reservations about using it on the '06. I try to be careful when parking but I have managed to scrap the lower front air deflector on some high curbs and if there was a lower bra attached it would be all scrapped up by now. I wish the front set up just a little higher.
  11. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    Got mine from Edward at sigmaautomotive.com
    Took about 45 minutes to install - very easy to do.
    So far after 2 tanks looks like MPG difference in minimal, but will know more after a half dozen tanks.
  12. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I've heard horror stories about the bug shields. One person even had it rub down to the metal. I'll never put one on my baby. They don't seem to help much anyway.
  13. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(AlphaTeam @ Aug 29 2006, 05:51 AM) [snapback]311030[/snapback]</div>
    The one from woodash.com, which is $89.95, does not touch the hood at any point, except for where it is mounted at about 5-6 points, on plastic clips that tighten as you tighten a screw into their sides. They give you small clear pieces of stick-on plastic film to put on the hood where the clips will go.
    Also, they give you some clear rubber bumpers, which are mounted on the hood itself, to protect the hood in case the trailing edge of the shield was to somehow press down and contact the hood. They stress that you have to mount the bumpers on the hood, not the shield, because if they were on the shield they would be moving as they contacted the hood paint.
    I've removed them from a couple of cars upon trade-in, with no residual effects.
    I agree with you that they don't seem to help much, as far as deflecting rocks away from the windshield (no way) or bugs away from the windshield (perhaps the skinny ones!), but I did seem to get an inordinate amount of little chips on the leading edge and 8" of my hood before installing the shields, so they do help there.
    rpm
