plastic fastener/proper name, care, and removal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by labumm, Aug 6, 2011.
  1. labumm
    labumm Junior Member
    62
    OK, this is a really dumb question. I'm sure the answer is somewhere in the forum if only I knew the name of this thing.
    Under the hood, there are black plastic fastreners that casually look like phillips head screws. If I pop up the center, they release.
    1) What are these called?
    2) What is the proper way to remove them? I am concerned that repeated removal using my carefull but unsatsifyingly clumbsy method will eventually break them.
    Clearley this is a fastener designed for assembly.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've heard those called by several names, not all them repeatable in a family forum. The name 'pop fastener' or 'plastic rivets' sounds more formal than 'those little plastic thingies', but most parts departments should know what you're talking about. They're designed for quick and cheap assembly, not repeated removal, and buying extra is a good idea because you're bound to wreck a few, or lose them as they go flying over your shoulder when you finally get them loose. Generally, the idea is to turn the phillips head part about 90 degrees - they are not threaded, so no point 'unscrewing' them - and then pop the centre part up. Then the whole thing should pull straight up and out. Once you've got one of the little buggers in hand, you can see better how they work.
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Easiest way to remove them is to push from underneath, you may have to turn them a bit with a phillips. Installation is the reverse, bring center pin up, insert, then push from top to reinsert. I think there is one that you cannot reach from underneath. There are reasonable substitutes in the Hardware store. Toyota charges $3.00 for each one. :bounce:
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I call them "f***ing plastic fasteners", usually followed by "g*dd**ned pieces of sh*t".
    That, of course, is technical terminology. Others may use something less formal.
    Tom
  5. Mendel Leisk
    41,873
    I find a paint can opener like this:
    very hand for the ones where you need to pull up the cap. Coupled with occasional help from a small flat bladed screwdriver.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Well Doh! I have bunch of those in my paint supply cabinet and never thought of using them for that. Thanks.
  7. triumph1
    triumph1 Member
    275
    Just picked some up from Lowes, in the hardware aisle.- They have some "Automotive" fastener drawers.
    Small bags of two, for $1.04.
    (Hillman) H# 881211 5MM
    2 people like this.
