Plastic noise near driver left knee
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by danwrite, Jul 24, 2016.
  1. danwrite
    danwrite New Member
    Boston
    Three Touring
    All passengers in my 2016 Three Touring notice some intermittent plastic noise near the driver left knee. Just a few squeezes sometimes. Definitely not electronic (braking or others). Feels like dashboard plastic noise.
    Sometimes a strong pat on the plastic in that region suppresses it.
    Anyone had similar experience ? Thanks.
    49,490
    welcome! does it happen at any particular time, acceleration, speed, bumps, turns, braking, etc.?
  3. danwrite
    danwrite New Member
    Boston
    Three Touring
    Not really.
    49,490
    so,it's all the time, or intermittently?
  5. danwrite
    danwrite New Member
    Boston
    Three Touring
    Indeed intermittent as mentioned in the post. It's not that frequent, but I definitely had it a few times every time I had a 2hr highway smooth drive.
  6. bisco
    49,490
    is that the door panel, or in front of it?
  7. danwrite
    danwrite New Member
    Boston
    Three Touring
    near the driver left knee, near the steering wheel adjustments, NOT on driver side door.
  8. bisco
    49,490
    there were a lot of complaints about dash squeaking noises on the early gen 3's. it's usually where to surfaces meet, like the left end and the side panel. i would let the dealer sort it out under warranty. it probably invokes removing the dash and adding material between the mating surfaces.
  9. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Welcome, dan. There's been a couple threads about squeaks/rattles in the dash area; or under the dash; or in the door panel. I believe the guys had a simple fix with some sticky foam tape?
  10. krmcg
    2,592
    2,390
    Whittier, CA
    White heater vent
  11. Coast Cruiser
    2,267
    2,571
    I heard two odd unusual sounds in my Prius this morning. I want to wait and see if I hear it again, before I comment further.
  12. WeiW
    WeiW Junior Member
    BC Canada
    Technology
    Had my 2016 Prius for 10 days now. Heard similar intermittent plastic noise as well but at different spot. Mine was at passenger side. I think it was one of the plastic panels on the door. I pressed down firmly on each of the parts on the passenger doors, which seems to be doing the trick. Haven't heard it for a couple days.
    Now I just need to figure out the inconsistent vibration on the brake pedal when car is stop with my foot on the brake. It is always when battery is around 2 to 3 bars. I didn't expect to feel that strong vibration when the engine is charging the battery, certainly not with inconsistency.It might be the white heater vent that has been mentioned in the forum. Going to my one month free inspection in a few weeks to get it checked out.
  13. Coast Cruiser
    2,267
    2,571
    Wei, I felt some vibration for the first time tonight. I was stuck in a long drive-thru line getting coffee. My lights were on, and the radio, and the AC. The battery went down to 3 bars. The engine kicked on, rather loudly, and I did feel some vibration but it wasn't very strong. I think it's normal? (And the battery went right back up to full when I started driving.)
  14. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I think we're experiencing some of the tradeoffs of buying some of the first gen 4s. First model year cars are always the worst put together ones. At least nothing's broken. I've had an annoying rattling sound in the right rear passenger side c-pillar. I'm going to get it fixed when I get an oil change.
    Coast Cruiser likes this.
  15. Coast Cruiser
    2,267
    2,571
    I've been pretty lucky. I think the "unusual" sounds that I have heard, were just the normal hybrid/electrical/pump sounds. I don't have any annoying rattling sounds anywhere in the dash or doors. No water spots in the headlights. Windows seem to fit tight. Body integrity seems solid. It's great when I come upon one of the few smooth roads, my Prius gets very quiet! :) It's wonderful.
    When the engine kicked on last night (and races and vibrates) to recharge the hybrid battery, it kind of startled me because I was sitting still at the time. But it only lasted a few seconds. It was another good "learning moment", and now I will know what to expect in the future.
  16. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    Are you sure it's not just your knee making the noise?:D
    Mine make strange noises more than they used to.:(
  17. danwrite
    danwrite New Member
    Boston
    Three Touring
    Thank you all. No, it's not just my knee... Four pairs of ears confirmed the intermittent noise. Will ask the dealer next time I visit.
  18. basemulot
    basemulot New Member
    Technology
    I have the same sound, check this plate and hold it when the sound appear. This plate vibrate with an other piece.
  19. Anastaceyrose
    Anastaceyrose Member
    60
    66
    I was just on the Toyota Owners website and found this comment to a question about a rattle....might be worth trying.
  20. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    And what's their fix?
