Plastic wheel cover
Discussion in 'Prius v Main Forum' started by Smily, Oct 14, 2015.
  1. Smily
    Smily New Member
    San Jose
    What is the reason to install plastic covers on alloy wheels? I had never had wheel covers when I got the factory OEM alloy wheels on my previous rides. Any specific reason Toyota is doing it? or am I making a mistake and my v-three comes with steel wheels?
  2. Mendel Leisk
    38,874
    Nope, wheel covers on alloys. My best guess as to why: some senior exec at Toyota must have made a suggestion to do that. How else to explain?
    Found this:
    One option would be to upgrade to 5, which I believe has a nicer, coverless rim.
    That's the route we went with 2010 Prius, bought a Canadian model that comes with nice coverless 17" rims.
    With the 2016 Prius even the 17" rims have plastic bits, 5 of 'em, one at each spoke.
    #2 Mendel Leisk, Oct 14, 2015
  3. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Mainly for a small effect on airflow over the wheels/wheelwells. The effect is negligible.
    Take the covers off and get some center caps to cover the open hole in the center.
    I took my covers off the hatchback within a week. They've been sitting in the garage since.
  4. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,805
    Texas Hill Country
    Besides aero they tend to protect the alloys from curb scratching
  5. mikefocke
    3,719
    1,662
    Sanford, NC
    Plastic caps off eBay. Unsprung weight versus aero.
  6. Smily
    Smily New Member
    San Jose
    Thanks all for your replies. I just ordered those center caps on eBay.
  7. Mendel Leisk
    38,874
    I had a try at "quelling" our front rust.
    Before:
    After various wire brush on methods:
    And after application of wax/oil rust inhibetor, very lightly btw:
    The solvents evaporate, leave a waxy costing. Hopefully will help, through the winter.
  8. tangcahyadi79
    tangcahyadi79 Junior Member
    17
    2015 Prius v wagon
    what the stuff name for cover on the center wheel
  9. Mendel Leisk
    38,874
    If you're referring to the wax/oil stuff I applied, I used: Lloyds corrosion Inhibitor & Lubricant. There are a lot of options; you want something that goes on oily, but a week or two later there is a waxy skin still there.
    Going from memory, the back wheels have a kind of chrome/gold colored cap in the center hub. I might spray that with black Plasti-Dip in a day or two. I could spray flat (or gloss) black enamel, but I'd prefer something more reversible.
  10. Mendel Leisk
    38,874
    Did a trial install of my steel rim, to see how the hub will look. I need to touch up the rim too:
    Well, cleaned up a bit.
