Platinum Cost in a Toyota FCV
Discussion in 'Fuel Cell Vehicles' started by wjtracy, Jul 25, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Lastest financial news has gold entering a bear market. I had thought maybe Platinum prices would stay up, but Platinum is tanking worse than gold at the moment. This article says Toyota uses 30-grams Platinum in an FCV. So that's just about 1-oz. or $1000 today (July_2015) and getting cheaper by the current trendline. Of course, it is quite easy to recover platinum after use, so presumably you'd get back most of that platinum at the end of the fuel cell life.
    The Cost of Platinum in Fuel Cell Electric Vehicles
    To put that in perspective, an automotive cat converter typically contains 3-7 grams Platinum (although they can switch over to Palladium). But a bigger truck cat converter can apparently approach 25-30 gram Pt, so in the same ballpark.
    #1 wjtracy, Jul 25, 2015
    usbseawolf2000 likes this.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Considering Mirai has no catalytic converter, the additional cost is less than some people try to overblow.
    dbcassidy likes this.
  3. Trollbait
    11,561
    For a $50k car, the platinum cost isn't big. For a $30k one, one to two hundred dollars for a catalytic convert is a lot less than a thousand for a fuel cell. But the high cost isn't just the platinum. There is the total cost of the total fuel cell and high pressure tanks. While those costs could come down in time, there is the high cost of a hydrogen network on top of that. So even if FCEVs get to ICE car costs, roll out will be slow, and the cars not even available in some ares because of those costs.
  4. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    You are preaching to the choir.
    DBCassidy
    Ashlem and lensovet like this.
  5. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    Presumably a CARB cat converter has some pretty good Platinum content...I guess they cost ($2000?) a lot in CA to replace. Its a little funny that Toyota opts to give every Prius a CARB cat converter, whereas FORD/GM I think tailor the car to CARB or non-CARB specs to save money in non-CARB states.
    Anyways a Prius is a $22000 car with a ~$1500 cat converter and a $3000 NiMH batt. Nissan Leaf is a BEV with probably a $15000 Li Batt. I don't think it follows logically that a FCV is fatally flawed because it has some expensive components. Or maybe it does make sense to say that, but then all green cars are guilty as charged.
    #5 wjtracy, Jul 25, 2015
  6. Trollbait
    11,561
    Catalytic convertors don't cost that much. It might cost that much to replace with labor, if the joints and bolts are all corroded.
  7. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    Like the cost of lithium in a tesla, the cost of the platinum in a fcv is not a big percentage of its price, but helps limit how low it can go.
    In a simple aluminum air battery you don't need to process the aluminum much, and could probably sell the battery at 3x the price of the aluminum, about $150 for a 1000 mile primary cell, and of course the aluminum oxide is recycleable to help pay for the next one. For batteries lithium must be alloyed and manufactured adding to the cost, and we are about $14,000 for the 70kwh (satisfactory price) battery to power a tesla for 240 miles using less than $1000 worth of lithium. Perhaps people can get it down to $70/kwh. The gigafactory will use more US lithium which is more expensive to mine than south american lithium, but this will have much lower transpiration costs (panasonic currently ships the lithium from south america to japan, then the cells from japan to california, versus simply mining and using the lithium in nevada with some tax breaks to support us mining jobs.
    For fuel cells the manufacturing cost is even more. That is where manufacturing innovation, or easier to work with materials (technical breakthroughs) come in. I would expect that if fcv start selling in the hundreds of thousands, which the doe thinks is necessary for the manufacturing costs to significantly come down, the price of platinum and palladium will rise. The key is technical advances at these lower levels to get the price down, or enough government money to get to the higher levels.
  8. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    GM, Honda join forces for one fuel cell design
    How's the progress on the fuel cell stack?
    It's coming down very, very quickly in terms of precious metal loading. The workhorse fuel cell stacks have 29 grams of platinum. The next-gen stack is down in the 10 gram range. The next generation is running in our laboratory now. Weight is down by almost one half. Size is also down by almost one half. And cost has come down in orders of magnitude.
    Source
    wjtracy likes this.
  9. austingreen
    13,574
    4,114
    Austin, TX, USA
    Nice from the interview
    It will be nice when they get the costs down so that variable manufacturing prices are bellow sales prices. Definitely not in this generation but maybe in 2 (ten years?) or maybe 5, or maybe never. If you lose money on each one, you won't be able to increase volume.
  10. hill
    8,187
    my understanding is that the Platinum stack elements were sized as small as possible to keep costs down. But if the precious metals markets keep tanking, that would be a great time to build a bigger stack. That would give Toyota's hydrogen car a better "oomph" off the line. What dues it do from 0-60mph? 10seconds? 12? A bit more power would be nice, if you're shelling out $57k. Plus, with a bigger stack, it wouldn't need as large a battery pack.
  11. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    ...should we call it something like Supercalifragilistic.mode? I do not know if amount of platinum is the limiting the power vs. flow rates of H2
