please bear with me...
Discussion in 'Prius c Technical Discussion' started by magtataho1, Apr 25, 2012.
  1. magtataho1
    magtataho1 New Member
    Delta, BC
    sorry if my question is probably nonsense to some but please hear me out. What if i will put a premium gasoline to my prius c, Does it make any difference at all in terms of performance (i know the recommended gasoline is 87 octane) Will i save more in terms of more mileages because I'm using a very fine gasoline but more expensive in gas prices?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    It will do nothing but drain your wallet faster! 87 is recommended for a reason!
  3. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    87 is the way to go. Higher octane doesn't mean a higher quality gasoline. It simply means it has better knock resistance. You're better off running the lowest octane that doesn't ping or knock. More energy per unit.
  4. richard schumacher
    7,663
    1,038
    United States
    What they said. Save your money. Why do you think that higher octane gas would be better than regular 87?
  5. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    agree using the higher octane is a waste of money
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The much missed Bob Wilson found no difference in a Gen 3 Prius gas mileage. He did find improved power when going up long grades using Premium, but it was not very significant. You have chosen not give any indication where you live, so it is hard to say if you have any long uphill grades locally.
  7. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    answers are:
    - it's nothing more than a waste of money.
    - performance is negligible, and will still cost you more than it's worth.
    - hell no.
    don't be stupid. don't waste your money.
  8. magtataho1
    Delta, BC
    Thank you for all the responses folks. Appreciate it.
  9. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    On this engine the best is 87 since that's what it is designed for. The best thing you can do is use Top Tier gas from any station on this link.
    Top Tier Gasoline
  10. priusCpilot
    631
    209
    LA
    I can see that. If it was 100+ out and climbing big grands, things would sure heat up fast. The engine would pull a lot of timing and maybe bleed out more air since it's a Atkinson Cycle to control knock?
