Please explain MPGe
Discussion in 'Prime Fuel Economy & EV Range' started by Pizza Driver, Oct 20, 2016.
  1. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    I don't understand all the implications of this number. Please explain.
  2. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A plug-in vehicle uses electricity as a power source. The MPGE rating is an attempt to estimate the overall energy efficiency of the vehicle and compare it to a standard gasoline driven car. I have always questioned the validity of these estimates as they seem to err in favor of electrical power.
    JeffD
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The EPA sets an electricity equivalent of a gallon of gasoline at 33.7kWh. This number is an overestimate most of the time, especially if you usually use 10% ethanol fuel. However, it's only an overestimate by a few percent.
    That MPGe number is how far the car will go (in some EPA driving cycle) on 33.7kWh of electricity *delivered from the wall during charging*. Thus, it includes all losses including those from the charger, the in-and-out losses of the battery, the power electronics in the car and the electric motor.
  4. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    I found here, this video explaining it well
    Jan
    Son of Gloin likes this.
  5. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
  6. bisco
    52,032
    it's good for comparing one car to another, but you don't get a readout when driving the pip, not sure about prime.
  7. Trollbait
    12,547
    Wikipedia also has a decent article on it. Miles per gallon gasoline equivalent - Wikipedia
    Short form is that EV efficiency is measured by the watt or kilowatt hours of electricity used. MPGe just converts that value into something that can easily be compared to a gasoline car's fuel economy.
    Since MPG is measured from the amount of gas that is put into car, MPGe also uses the electricity amount put into the plug in. This means it accounts for the energy lost to the charging process.
  8. jdenenberg
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Note that they are comparing about $0.07 worth of electricity to about $2 worth of gasoline (classic apples to oranges comparison). I do not agree with the equivalence unless you do a full efficiency analysis from energy source (coal, nat. gas, hydro, wind. solar for Electricity vs. crude oil for gasoline) to motive power. I did this once to compare my kerosene burner to an electric heater (both are about 100% efficient) and the kerosene burner won easily due to the delivery inefficiency of the power grid (even assuming the fuel cost for the power grid was lower)
    JeffD
  9. Lee Jay
    5,850
    4,036
    No, 33.7kWh is not 7 cents anywhere.
    The delivery efficiency of the power grid is over 92%. You must have been including the thermal efficiency of the power plant, which is very hard to define when the sources are renewable.
  10. jdenenberg
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A slip of 2 decimal points ... point taken
    JeffD
  11. Trollbait
    12,547
    These numbers aren't meant for such level of analysis. They are meant to be used by consumers as a way of comparing the fuel efficiency of two cars with different fuel sources in the process of selecting one or the other. The cars themselves have no influence on the efficiency of how the electricity or gasoline was made and got into the car, so has no direct relevance on on these numbers.
    As for cost, the window sticker that these figures are posted on includes the annual fuel cost as well as the cost to go 25 miles for the car using national averages. So does Fueleconomy.gov, and that site lets the user adjust those average values for more personal figures.
  12. HypersonicPrime
    75
    59
    NC, USA
    Is it just me or does the Prime not have a good display of overall (gas+electric) energy efficiency? The listed MPG is misleading because it doesn't include energy from the grid. The "Drive Monitor 2" miles/kWh doesn't include energy from gasoline. The only method I can envision to calculate an overall energy efficiency (MPGe) is the following: EV, HV, MPGe calculations... | PriusChat
  13. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I'l tell you what is is NOT:
    It is not a useful way to compare an EV to an ICE
    Doing so gives you wrong answers if your exercise is money, GHG emissions or criteria taipipe pollutants.
    ICE vs ICE ? sure
    EV vs EV ? Clumsy, but go ahead
  14. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    MPGe is very good at what it is. A measurement of the efficiency of plugin vehicles.
    I do agree it is terrible if measuring cost, or carbon or pollution.
    Just as a ruler is terrible at measuring something's weight.
  15. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
  16. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I've been trying to come with an analogy for a while. How about this:
    Is a pound of fibre equal to a pound of sugar ?
    Both are one pound
    Both are carbs
    They have similar embedded calories
    And yet to a human they have very different utility. Fibre is good for a bulky stool; sugar will move you.
    And while fibre can be broken down to sugar by some animals, it takes energy to do so. That energy is not reflected in our initial comparison.
  17. pilotgrrl
    891
    1,797
    Chicagoan in TX
    Sorry, hit Send instead of backspace...
    ~$0.07 is about what I pay for 1 KWh of electricity. It's pretty exciting to me that that is about equal to $2 worth of gasoline.
    It's the little things in life that make me happy...
  18. Zythryn
    6,408
    4,407
    Sure, they are equivalent weight. So a scale would be exactly correct, stating they are the same weight.
    If you are trying to measure utility, weight is a very poor measurement.
    MPGe measures pure efficiency. Don’t try to use MGPe to measure something else.
  19. Lee Jay
    5,850
    4,036
    I don't know how you got that, but it's certainly not.
    RonMc5 likes this.
  20. pilotgrrl
    891
    1,797
    Chicagoan in TX
    I got it from #8: "Note that they are comparing about $0.07 worth of electricity to about $2 worth of gasoline".
    RonMc5 likes this.
