Please help. 07 Prius died an hour ago on the road and won't start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DomL 07, Feb 7, 2018.
Tags:
  1. DomL 07
    DomL 07 Member
    I hope someone has an answer.
    I have 230,000 miles on my Prius.
    I was just on Route 287, almost on the Tappan Zee bridge when my 07 Prius shut off.
    The dash went black, and nothing worked.
    I had headlights, and interior lights, and flashers, but nothing else.
    I had to be towed off the bridge.
    What the heck happened and is there something I can do, or, does it need to go to the dealership/
  2. JC91006
    16,468
    8,383
    My guess would be a shorted inverter pump. There was a recall for this item a few years ago. If you have not done this recall, the repair would be free at the dealer
    But this is just s wild guess
    Dxta likes this.
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    And/or it's large fuse. Sounds like the car is only working on 12v now.
  4. DomL 07
    DomL 07 Member
    A wild guess is better than what I have so far, which is a dead car. Thank you ! I had it towed to a dealer and will have them check it tomorrow. Thank you very much !
  5. DomL 07
    DomL 07 Member
    The car pretty much didn't work at all.. If it was on the 12 volt battery, wouldn't the gas engine work ?
    How do I find and check the large fuse ? Or, is it something the dealer has to do ?
    Thank you !
  6. fotomoto
    5,597
    3,771
    So. Texas
    Nope (short answer).
    The inverter fuse is a large 100amp (IIRC) metal unit which is a speciality item. If the inverter pump is going bad (they are a somewhat common fail point) it might draw enough power to blow the fuse but most likely the inverter pump failed which makes the car stop as the hybrid electrical side can no longer work properly. It could be both.
    The dealership will read the trouble codes and let you know what happen anyways. Please report back.
    GOOD LUCK!
    SFO likes this.
  7. JC91006
    16,468
    8,383
    The most likely fuse that blew here is the AM2 fuse and it disabled your car. The cause should be related to the inverter pump.
    I don't have many examples where the car dies like that, except when the inverter pump gets shorted. Other causes could be bad fuel pump, running out of gas etc
    SFO likes this.
  8. DomL 07
    DomL 07 Member
    It's not gas. Filled up this morning with a bar and a half left. Fuel pump..... maybe, but, seems to be electrical. If the fuel pump went, wouldn't it work for a little while on electric ?
    Thank you !
    Dom
  9. DomL 07
    DomL 07 Member
    Thanks !
    I hate going to a dealership. I always feel like I was ripped off. That being said, I have never been to the one in Stamford.
    Hopefully I get that warm and fuzzy feeling. lol Not probably. lolol
    Thank you !
    Andyprius1 likes this.
  10. DomL 07
    DomL 07 Member
    Never had it done. The paper is still hanging on the wall in the office.
    Tomorrow will tell.
    Thank you !
    I will keep every informed.
    SFO likes this.
  11. JC91006
    16,468
    8,383
    Well I think you'll get some good news......along with some upsell of other services that you "need"
    SFO and Raytheeagle like this.
  12. DomL 07
    DomL 07 Member
    Quick update for you guys on here. Well, half of one anyway.
    Went to Stamford Toyota this morning. Spoke with Rich, who seemed very knowledgable about the problem.
    His first comment is that it's probably the 12 volt battery. I explained that I had lights, but he still thought it was.
    When I said it was the original battery ( almost 11 years old now ) He was surprised and said it almost certainly
    was the battery. Most last 3 -5 years.
    A few months ago I had problems with my instruments not lighting and then the car not shutting off and the thought
    on this forum was the battery. If thats all that it is, I'm very happy.
    He also said there were a couple of recalls and they would do the work on them too.
    As JC91006 said, I am very pleasantly surprised with these people. If I didn't work part time for Ford, I would
    take my Prius to them every time !
    Thank you all for your input, and I will update when I get the final results !
    Thank you all again !
    Raytheeagle and Prodigyplace like this.
  13. Mendel Leisk
    38,199
    Not that it really matters, but that's north end of New York, New York State, USA.
    Prodigyplace likes this.
  14. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    What kind of MPG you were getting with your 11 year old battery?
    Raytheeagle likes this.
  15. DomL 07
    DomL 07 Member
    I am getting 46 + mpg. On regular tires ( not the special ones ) and doing at least 65 most of the time.
    When I slow down a little, it goes almost to 50mpg.
    But then, people are shipping past me. lol
    Raytheeagle and SFO like this.
  16. DomL 07
    DomL 07 Member
    Final update. Fuse blew because of recall that never got fixed. No charge.
    However, Upsale is: I need tires ; and alignment ; 2 front marker bulbs ; an oil change ; and some sort of a piece
    in the steering column thats not dangerous, but makes a click or a clunk when I turn. ( I never heard it )
    Oh, and both air filters. ( almost 100.00 for them )
    Going with the 2 marker bulbs and the oil change.
    The best parti of this is, I like the dealership and will probably go back for any other work.
    They, and least Rich, did good with me.
    Again, thank yo all for your input. It calmed my nerves last night.
  17. DomL 07
    DomL 07 Member
    I was going from Rockland to Westchester. The car went dead just before I was actually on the bridge.
    Another 5 seconds and I would have been on the actual bridge.
    As the saying goes, " God watches out for little children and idiots" I am the latter ! lol
    Prodigyplace and Mendel Leisk like this.
  18. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    That steering column shaft issue should be a free recall if I'm not mistaken : https://nhtsa.gov/recalls
    Bought a bag of 20 marker bulbs for $1.08 total, with free shipping. Took about 30 seconds to install each side.
    The two air filters cost about $10 total (online) and took about 2 minutes for install.
    Hopefully that oil change is affordable.
    https://priuschat.com/attachments/t-cp-c1u-a110-d-pdf.43951/
    #18 SFO, Feb 8, 2018
    DomL 07 and Raytheeagle like this.
  19. DomL 07
    DomL 07 Member
    They want $ 469.00 for the steering shaft. I guess it's not a recall because he checked the recalls. Not going to happen. lol
    I don't see a price on the bulbs, so, even though I think I told him to change them, they weren't.
    He never asked me if I wanted conventional or synthetic oil. They did conventional and I've been using synthetic.
    I hope this doesn't mess anything up. Next oil change will be much sooner than 5000 miles.
    And, at Ford again !
    Going to pick up bulbs today. Either eBay or Advanced Auto Parts.
    And, both air filters.
  20. DomL 07
    DomL 07 Member
    A little funny update.
    Got is the car last night. Had problems getting the door to unlock. Thought the battery had had it.
    Got is the car and it wouldn't start. Crap ! Not again ! What the heck ? They just fixed it. Or, did they ?
    Figured I'd call the dealership this morning.
    Used my wife's car. When I got home, I tried it one more time. This time, I happened to put the key fob in the holder.
    Car started right up. oops. Have to remember to turn the remote key fob switch back on.
