Please Help! 2007 Toyota Prius P lock malfunction/ won’t ready
Discussion in 'Gen 2 Prius Main Forum' started by Daddytothreeboys, Mar 13, 2023.
  1. Daddytothreeboys
    Daddytothreeboys Junior Member
    Hello, I have a 2007 Toyota Prius that I recently acquired that was in need of a new hybrid battery after sitting for too long. I replaced the 12v as well as the hybrid battery and now the car has a “p lock malfunction” and tells me to park the car on a flat surface and set the parking brake. The power light is orange and I can only press the button once and it goes on (accessory mode?) but a second push turns the car off. From everything I’ve read it should be two pushes for ignition/on with out foot press of the brake. Am I mistaking? Also, there is a light that flashes that looks like the gear shifter? On the left side of the dash after you have turn the car off, with the key still in. I can’t find anything about that anywhere so if anyone knows anything about that, it might help me solve my issue. I have tried everything I can find online about similar issues, such as rocking the car to try to get the car to lock into park (maybe the pawl is in between and parking lock isn’t engaged?) not sure if that was really going to work as I also read the Prius has an electronic pawl and a motor moves it in and out of place and sometimes it needs to be relearned? Putting the car in and out of neutral and park with or without jumper cables to try to get the pawl to “learn” where it needs to be. Nothing has worked. I tried a jumper wire from the p control fuse to the transmission control wire as well. I feel might be helpful to mention the car doesn’t shift into anything but neutral and I’m not sure it even does that because it doesn’t seem like it’s really shifting. Also, the parking button light never lights up green? Not sure if anyone can help or knows anything but it all helps I’m so stuck and would like to fix this. Thanks. I’ll add pictures later.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Sounds like a 12v issue. What voltages do you measure at the jump point under the hood, and again at the 12v battery in the rear?
    Yes. To "ready" you must press the brake as well. If needed, download a copy of the manual : 2007 Toyota Prius Manuals & Warranties | Toyota Owners
    FYI : you're moderated until you've posted 5 times.
  3. Daddytothreeboys
    The voltage is good at both the jump point and the rear. I have this light I’m not sure means anything but I have attached a picture. Today i received a VeePeak OB2 reader to use with the Dr Prius app and was able to get the code P3102 the only code I can get. I have read stuff about tech stream being the best way to diagnose but I’m trying to figure that out, is it possible I’m not pulling all the codes without tech stream? I’m just not sure. Thanks for your response.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Techstream is a capable option. Bootleg versions on amazon or eBay can work (or not). Legit versions costs a bit more for a "good" Vehicle Communication Interface cable and a (short term) software subscription.
    Another option is to read this thread reviewing scantool apps and devices for smartphones. You might want to look at ones that can retrieve INF or sub codes with added information about a fault.
    DrPrius is good for what does, but is very limited. You need something that can scan all systems on your Gen2.
    Your code indicates that the hybrid control ecu doesn't like something about the "transmission control" ecu (it's the system that engages the parking pawl on the trans)
    https://priuschat.com/index.php?posts/3290690
  5. Daddytothreeboys
    Okay that makes more sense do you think it could be the transmission control ecu itself? Or that would require further diagnostics to know for sure? Thanks for your reply.
  6. mr_guy_mann
    4,083
    1,995
    NJ-USA
    Sometimes, there are codes where the diagnostic "procedure" is - replace XX part. In most cases however, there are tests that have to be performed before you can be sure. (it's fairly common that Mr average DIY will just "fire the parts cannon" and replace things)
    A fault with the parking pawl system isn't really common, so I would find out the INF code and follow the factory diagnostic procedure.
  7. Daddytothreeboys
    Alright, thank you so much I have figured out my next steps. I’ll try to figure out the INF code and go from there. I’ll update with anything I find useful to diagnose or my solution.
  8. Daddytothreeboys
    Okay so major update. I followed the advice of SFO and o double triple quadruple checked the 12v. Let me explain, I got a brand new 12v for the car because I knew with the age of the battery and how long it had been sitting the 12v was toast. For kicks and grins I attempted to jump the toasted 12v with poor results. I was able to lock the car electronically which was nice. I installed the new 12v battery (took less than 5 minutes) and thought the problem would be solved. No, same issue. I tried to jump the new 12v, nothing. So, I took the new 12v out yesterday and trickle charged it back to a full charge and decided to put it in reading a soilid12.6 V. First I made sure all the connections were clean, I thought they were clean but I still cleaned them, then installed then new 12V and BOOM we have resurrected another one. It started up and I was able to drive it around to get a good charge back on the hybrid battery after I put some fresh gas in and oil the good stuff so now I can put it back together freshen the fluids and she will be a daily driver again. Long story short check the 12v always check the 12v. Thanks to everyone in this forum I wouldn’t of made it without you or the support of my amazing wife.
    SFO likes this.
  9. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    So, what changed between the first and second install?
    Your story seems to indicate there was not a good connection somewhere the first time. Did you find some connection was loose? Or were your terminal brackets coated in corrosion on the inside?
    I am just asking so the next person to read your post has something tangible to check.
  10. Daddytothreeboys
    There was a bit of corrosion, I thought I said that I my post… it seemed like very little corrosion to me and I didn’t think it would cause an issue. It was either that or my 12v had a slightly low voltage at purchase? I’m not sure just check connections, corrosion and everything with the 12v first. I suspect corrosion was my problem.
  11. dolj
    dolj Senior Member
    8,546
    4,341
    I see. Yes, it always pays to charge a new battery before installing it.
    Daddytothreeboys likes this.
