Please help identify this part that appeared during a Head gasket job
Discussion in 'Gen 3 Prius Technical Discussion' started by poway, Mar 3, 2025.
  1. poway
    poway Junior Member
    Pensacola FL
    There's two of these, and they appear relatively clean .Thanks! View attachment 268725
    #1 poway, Mar 3, 2025
  2. PriusCamper
    PriusCamper Senior Member
    12,769
    5,173
    Pacific Northwest, USA
    Aren't those relate to the valves, or valve guides?
  3. ChapmanF
    18,213
    Are they oily at all? Things to do with valves or valve guides would have been under the valve cover where everything is oily.
    Another possibility I'm thinking might be fuel rail spacers, but I'd expect those to have some dust/grime.
  4. Tombukt2
    Tombukt2 Senior Member
    12,989
    2,328
    Durham NC
    That's what I was going to say fuel rail spacers and look exactly like that
  5. Tombukt2
    12,989
    2,328
    Durham NC
    And there's exactly two did they come in the head gasket set? Are you back together You would be squeezing the ever living goodness out of your injector rail if those weren't in place or you'd have leaks or or or.
  6. poway
    poway Junior Member
    Pensacola FL
    Thank you all! It appears to be part 23807V. Here's a big hug to all!!
    Grit likes this.
  7. Mendel Leisk
    41,463
    When taking stuff off, it’s good to have trays, tubs, bags. Label them all. Array them in order removed. Take copious pics too.
    I know, hindsight.
    one ingenious ploy I saw (YouTube video): guy had printed out the Repair Manual timing chain cover pic, the one ID’ing all the bolts and torque values, on what looked like 11”x17” paper, taped it to cardboard, jabbed through-holes at each bolt location, and pushed the bolts into their corresponding positions as he removed them.
    #7 Mendel Leisk, Mar 4, 2025
  8. Tombukt2
    12,989
    2,328
    Durham NC
    I just throw everything in the number 10 what is it called a coffee can You know like Maxwell House it says on it but yeah that's what I thought those are definitely the fuel rail spacers and they need to be there thank God you didn't try to put it together without that has happened before It's kind of hysterical
  9. Mendel Leisk
    41,463
    Throw everything small in one can, put on the lid, and shake it up good. :)
    bobby515, Tombukt2 and Brian1954 like this.
  10. bobby515
    bobby515 Member
    181
    phila
    Taking pictures are really good as you take things apart.
    ASRDogman likes this.
  11. PriusCamper
    12,769
    5,173
    Back when I was a kid I'd take stuff apart when I got home from school and would get stressed about if I could put it back together or not before my mom got home from school. Back then taking pictures wasn't an option... It's more fun that way!
