Please help me diagnose this
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Feb 27, 2020.
  1. ATlam
    ATlam Member
    64
    57
    San jose
    Lately my car been having rough starts the first minute and then it runs great after that (mileage is still good). Engine throw a code which I looked up to be cyl 2 misfiring . Coolant is a quart low. I assumed it's the head gasket leaking coolant slowly into cyl 2 which cause the shaky start. This car has 266k miles and I was planning to replace it in 2 years so I put in head gasket leak repair hoping to bandaid it for another 2 years. Problem seems to go away for 2 weeks or so and now I got engine light and really rough start.
    I think this is important but after the rough start, if I turn off the engine and turn it back on there is no noise, so this is only for cold start!
    I will upload a vid file when I get home, thanks for the help!
    #1 ATlam, Feb 27, 2020
    Priuslover09 likes this.
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    What are thee codes?
    pjksr02 likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Your first assumption likely is correct.
    The "snake oil" you put into it is really not intended for use over a 2 year period; more like 2 weeks to 2 months.
    AND the water leaking from the cooling loop likely is ending up in the crankcase with the oil.
    Have you checked the oil lately ? Is there frothy white stuff on the dipstick or inside the filler cap ??
    Sounds to me like you need to move up your "new" car timetable about 2 years.
    At some point, the engine will not be salvageable.
    It sounds like that is happening sooner than you hoped.
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I never heard of snake oil
  5. sam spade 2
    7,035
    2,788
    2017 Prius c
    Google it.
    It refers to selling something that is mostly or entirely a scam.
    MANY automotive additives fall into that category.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I don’t use google I use yahoo but I will look it up
    m.wynn and Grit like this.
  7. ATlam
    ATlam Member
    64
    57
    San jose
    Hi guys, its not technically a snake oil, a lot of people have success with it as a temporary solution for low head gasket leak. It supposed to fill up the leak and turned into solid as it cooled down. (the cap on my bottle broke during shipment and the liquid filled the crack on the cap and turned solid, it's pretty cool to see!). It does not work in all cases, just very minor head gasket leak.
    Here is a video i made of the noise during cold start up.
  8. ATlam
    ATlam Member
    64
    57
    San jose
    After the noise dies down, I had no problem driving home. Acceleration was smooth with no loss of power.
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok did it fix the problem¿
  10. ATlam
    ATlam Member
    64
    57
    San jose
    No, the problem is still there. I'm just stating that after rough engine start, it drives just fine. But the problem will still be there the next time I cold start the engine :(
  11. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Did you check the oil was good?
  12. ATlam
    ATlam Member
    64
    57
    San jose
    yes, oil is clear, no signs of coolant.
  13. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Did you check the inverter so make sure it’s okay!
  14. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    m.wynn and Cosmo Tigato like this.
  15. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    So you're the one.
  16. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    I prefer goduckgo
  17. ChapmanF
    15,589
    not duckgoduck?
    jerrymildred likes this.
  18. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I use that before but I don’t like as much as yahoo
  19. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    I never heard of goduckgo
  20. sam spade 2
    7,035
    2,788
    2017 Prius c
    Well then it may NOT be a head gasket problem at all.......which would explain why the "gasket sealant" didn't help any.
