please help!! prius not accelerating (limp mode?)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hershey1203, May 18, 2025.
  1. hershey1203
    hershey1203 New Member
    chicago
    hello all! i recently got a 2005 prius after my nissan maxima was totaled (rip). ive had it since december. in February the red warning light came on, then in march the engine light came on. it had been driving fine besides the lights, until one day while driving on the highway all of the lights on the dash turned on and the car started to shake slightly. took it to the nearest autozone to get a read (a useless attempt) and they told me they couldnt do anything. ended up driving the car back home to the toyota dealership and they said I had a bad 02 sensor, a headlight level acctuator that needed to be replaced, and a bad speed sensor. other than that, nothing. wasnt willing to pay over $3,000 dollars to get it fixed considering i bought it for 4k, so i left. slowly the cars gotten worse, has trouble accelerating and after about 15-20 minutes of driving at 45 miles an hour (quicker on the highway), the car goes into what i believe is “limp mode” and will not accelerate, even stepping on the brakes. if i turn the car off and then on again it goes back to running fine for 15-20 minutes again. battery screen is showing charging normally ‍♀️got the 02 sensor fixed today and hoped that would fix it but it did not. went into limp mode after 15 ish minutes. please help!!!!!
  2. Paul Gregory
    Paul Gregory Senior Member
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    I'm sure your dealer has a better opinion,
    but it sounds like your engine isn't running.
  3. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    Yeah I don't know about the limp mode business you must have codes you keep going around in circles with all these mechanics and dealers and folks but nobody tells you any kind of codes they just tell you they're going to replace an O2 sensor and a speed sensor and a so on to me that doesn't even sound like that would fix the problem and I don't know why anybody would think that but I guess it sounds good coming out of mechanics mouth sounds like you're having pool running engine code 31 something whatever it is not necessarily engine won't start but poor engine running there's a whole section to troubleshoot that just like you would a regular car spark plugs ignition parts mass air flow sensor cleaning so on and so forth but in order to know these things you might have to understanding have some desire to have some mechanical background going on or something or some kind of an interest not just the fact that your car is not running right A lot of people don't have that so then you wind up just firing parts cannons and everything sounds sensible to you because well you work in a restaurant or whatever the case may be not shaming anybody don't care about all that but you need the codes that all the people are not wanting to give you for some reason so they can keep you strong along so you'll keep firing the parts cannon at the AutoZone kind of like drug addict behavior you know what I mean. So get the codes or spend the $68 and buy an ap200 you can Google it made by a company called a u t e l no self-respecting Prius owner should be without a scanner so they can be lied to and told all kinds of stories and walk around the whole city the long way just to get back to their house it's just silly but if that's interest you and that's the kind of behavior you want to pursue well you're well on the course you need to get the codes. Point blank without that you're pissing into the wind and it's getting you really wet
  4. hershey1203
    chicago
    according to my toyota dealer the only problems are the ones ive listed…. thinking ill just have to get a scanner so i can find the truth out myself‍♀️
    agreed! i feel like im running around like a chicken with its head cut off! thinking ill take your advice on getting a scanner, the dealership told me those were the only codes that showed up besides a few recalls that they fixed for free.
    #4 hershey1203, May 18, 2025
  5. ChapmanF
    17,174
    I trust you meant "stepping on the accelerator"? Mine also doesn't accelerate when stepping on the brakes.
    The symptoms sound a lot like what happens if the power electronics are not getting cooled well enough. Drives ok until they get too hot. A capable scan tool might show a code related to that cooling system, like P0A93 maybe. (But use the capable scan tool, not my guess.)
    Brian1954 likes this.
  6. hershey1203
    chicago
    i definitely meant the accelerator (if its not obvious, im not well versed in car lingo LOL).
  7. hershey1203
    chicago
    edit: reading other prius chat posts and remembered something (ive been on vacation for two weeks and havent driven the car so forgive my memory), but when the air conditioning, lights, and bluetooth converter are connected it seems to make the car run slower and make it go into “limp mode” faster. ordering the scanner other comments have mentioned to hopefully find out whats going on!
  8. Tombukt2
    11,994
    2,119
    Durham NC
    Look into that ap200 for that little money it's a good deal for all the features and services it can perform in my eyes no self-respecting owner of a car this kind of complicated should be without such a simple inexpensive product that can stay in the console your pocket whatever it's also an excellent eobd scanner so in your vault and your Civic and all cars it will read codes that other scanners can't read it's bi-directional it's pretty much up to snuff works with Android 14 now I mean it's just too easy then at least you have the numbers I mean I guess shops now you have to beg these people to give you a printout just a few years ago it was mandatory now it's like they act like they've run out of paper or something funny how things like that arise at certain types of places you know usually it's income generating is what it is.
  9. hershey1203
    chicago
    hey all, just an update incase anyone runs into the same symptoms- it is in fact the battery that is dying. thank you all for the advice!
