Please help this low-income single mom!!!!
Discussion in 'Gen 2 Prius Main Forum' started by Vona Williams, Sep 6, 2023.
  1. Vona Williams
    Vona Williams New Member
    Talladega, AL
    I'm in a program for homeless women and children and was recently donated this car. It's a 2006 Toyota Prius and I was told that it had just had the hybrid battery replaced within the last year and a half.
    I've had it for only a month and a half and the only problems I've ever noticed is it does take a bit longer than normal cars to really get up to speed when driving normally but I thought that was because it was a hybrid and it also doesn't get as good of gas mileage as I saw that it should online. It was getting about 45 and now it's barely getting about 33.
    I got in the other night and out of nowhere a bunch of lights on my dash are on. The lights are the big triangle of death, the yellow brake warning light, the VCS, and the check engine. At first it drove fine even with all the lights on but now when I try to drive it at all it refuses to accelerate properly and won't charge the hybrid battery unless it's sitting idle.
    I had my codes ran at AutoZone and they came up C1256, C1259, and C1310.
    I'm at a loss and no one seems to know anything about hybrids. I'm considering giving up and trading it into carvana while it still runs. Please help me!!!
  2. Tombukt2
    Tombukt2 Senior Member
    9,221
    1,618
    Durham NC
    You need to find somebody local to you which I don't know where that is I'm in the southeast United States North Carolina Middle of and need somebody near you to read the codes with the proper scanner and get everything else just to make sure those are break codes usually you hear the brake pump running when you get in the car and open the door if you just sit there for a minute and listen you hear things pumping and whirring etc.. unfortunately that part is quite costly around $1,700 walk-in price maybe 1435 internet price walk-in and pick up either way it's very costly sometimes you can get away with taking one off of used car and be lucky for a while maybe a longer while who knows use there about 340 bucks something like that again It's hard to say I don't know where basically you are so this is all based on the Central Southeast United States basically oh and good luck.
  3. Tombukt2
    9,221
    1,618
    Durham NC
    Oh you're from Talladega Very cool we're from the other T town Tuscaloosa Roll Tide. You should have really no problem finding an abundant of these things used in the junk yards when I'm down there visiting family there are a few places I always stop at on the way down because it's a good idea they're also some big places in Georgia right across like in Conyers miles and miles of these cars.
  4. Leadfoot J. McCoalroller
    7,184
    6,734
    Pennsylvania
    2018 Prius c
    Honestly that's not a terrible idea. Older hybrids can turn into moneypits, and yours is showing signs that the replacement battery is not all it should be.
    sam spade 2 and JohnPrius3005 like this.
  5. ChapmanF
    15,704
    The C1259 and C1310 aren't unexpected, but all they mean is that the real news will be in the hybrid system codes that the AutoZone scan hasn't shown you. (A lot of scan tools can't show all the codes in a Prius.)
    Best bet is to find someone who has a tool that can read all the codes in a Prius, and then tell us what they all are. That could be someone who has Toyota Techstream (the same software a dealer would use), or who has one of the better scan tools reviewed in this thread (which mentions which ones can show all of the codes):
    Gen2 OBD2 app review | PriusChat
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    If you are not "mechanically gifted" & DIY capable (or know someone who is), then as mentioned, an old hybrid isn't a great choice.
    It might need a sizeable repair budget.
    JohnPrius3005 likes this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    8,003
    4,742
    Texas Hill Country
    Odds are the hybrid battery was replaced with a used one that has gone bad again. Pretty common. The problem is a new one is at least $2500 installed and you still have a very complicated hybrid that most mechanics don’t work on or know much about.
    Even an accurate diagnosis at a dealer is around $150.
    Carvana is not that good of an option either since they won’t give you more than a few hundred as a trade in and zero if you try to outright sell it to them. All of their cars are overpriced for someone on a tight budget.
    So you are between a rock and a hard place. The best Prius fix would be a guy or shop like Tom who has hybrid experience and knows where to get parts. But it is likely to be one thing after another.
    The best bet is another car from a friend but this time get a conventional budget friendly car anyone can diagnose and repair.
    Budget Oldies But Goodies (w Lower Miles)
    2000-04 Avalons (no rust)
    2004-06 Camry V6
    2005-08 Corolla (very good)
  8. Mendel Leisk
    38,753
    Any car, hybrid or not, is a financial burden. An older car, with maintenance unknowns, and having precious little “discretionary income”, yeah just convert it to cash, and keep that for a rainy day.
  9. Tombukt2
    9,221
    1,618
    Durham NC
    Yeah but something like a 1995 or 6 7:00 a.f. 1.8 Corolla. Will roll forever with minimal everything. Step up to a 2002 AE11 1ZZFE engine You've got something there too high mileage can be a problem with oil and what have you but the engines are plentiful on the JDM market Don't waste time with rebuilding like the two Z just grab another one and that will take you until you don't want to drive anymore literally unless you're where it rests then just figure every two or three years come down south by a replacement take it back up north something along those lines I've done that for years when I lived in Western Massachusetts.
  10. bisco
    49,523
    anyone seen my mom?
